![]() | Home > Off Topic > Anyone here install electric underfloor heating? |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2063 ![]() ![]() |
I used this a approx 5 years ago in my lounge with their insulation:
http://www.1926woodflooring.co.uk/acatalog...ments.html Not for bathrooms though. This might be better in your en-suite?: http://www.1926woodflooring.co.uk/acatalog...ating.html Last edited by DAZ110 on 17th Nov 2016 10:04am. Edited 1 time in total |
gabe3105 Member Since: 25 May 2015 Location: Grimsby Posts: 237 ![]() ![]() |
I think your advice is correct. You need to make sure your chipboard floor is well screwed to minimise movement. I would be tempted to use a specialist tile backer board like hardie backer or no more ply, rather than standard ply (I assume you will be tiling over it?). They have the benefit of being only 6mm thick too so are useful if floor height is an issue between different rooms. No prime required. Be careful if tiling directly on top of the wires as it is easy to damage them with a trowel...
andy---doe Member Since: 14 Mar 2015 Location: Yorkshire Posts: 188 ![]() ![]() |
Rather than ply use Thermal Tilebacker Boards. These fix to your current floor and will send the heat upwards (rather than into your floor) and also level your floor the same as ply.
Loads of different ones but example:- https://www.tlc-direct.co.uk/Products/BNFB...0wodpQ4Evw |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
En-suites and underfloor heating in a Defender. What a great idea! 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 687 ![]() ![]() ![]() |
I have just done our ensuite (concrete base) and got all the stuff from here.
http://www.theunderfloorheatingstore.com/ Load of tips and videos to help. |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6670 ![]() ![]() ![]() |
Moved to
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1369 ![]() ![]() |
Scott, thats where i bought it from, i have just ordered the backing board from them and a bottle of primer, thanks for your help everybody, much appreciated.
I drive concrete mixers and have covered acres of underfloor heating systems and the professional layers use a product called Durament or Hyflo concrete. It is a by product from power stations sourced from Germany. Zero stone just sand durament and super plasticiser applied at almost treacle like consistency and self levelling. Use in flats, schools and offices and usually top end homes. It is a joy to see it turning a bare building into a finished floor. £250PCM approx. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
