Home > Maintenance & Modifications > Advice on 'lifting' the vehicle by 2"
Page 4 of 4 <1234
K9F
BigMike wrote:
and if the latter, then that's cool but for me, I would question why a lift is something actually wanted when it can lead to other issues which the warranty would be unlikely to cover in the event of component failure..
BigMike,
I am not ashamed to admit that I am in the 'latter category' I like the look of a raised vehicle such as Fekete's! I am also highly impressed by the 'standard Censored ' fitted as they work perfectly well for my style of driving and the conditions I drive in! There are many conflicting rumours and conjecture as evident from this thread! Initially my vehicle was 'booked in' next week to be done! When I queried the castor issue on a subsequent phone call I was 'advised' to have the radius arms done as well, either by replacing or bushing! My confidence then waned! No mention of this on the initial query as I didn't know any better! To me it seems that even people in the trade are unsure 100%. Booking has been cancelled until I can determine what is best for me, if and when I can afford the luxury or indeed whether to spend my hard-earned on something else instead I shall read with interest the posts on this thread! The warranty is not really an issue as with all my modifications it is I'm sure null and void! Hence my reasoning behind finding out as much as I can! I don't like doing Arfur! Arfur job!!!! Laughing You have also twinged my conscience as I do not really need it! Thanks! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #56237 2nd Feb 2011 5:00pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Mal i've tried and tested standard Censored to after market and the difference being the shocks is quite amazing as i've said in previous post.... i noticed the difference when driving over cobbles and the landy use to shake to bits now with the Bilstein on the ride is smooth ?
Have you considered these i've got a set of 1" on the front to level the landy... they work great...just a thought if your happy with your stock stuff
http://www.gwynlewis4x4.co.uk/page54a.html NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #56246 2nd Feb 2011 5:25pm
K9F
Damn cheap option that Karlos...May do a bit o' further digging to see if they're as good/easier to fit as the shorter turret option! Thanks for the linky fingy! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #56306 2nd Feb 2011 9:31pm
Glynparry25
Mal, the turrets and spaces are 2 completely different things.
The spacers lift your vehicle and no other modifications will be needed.
Turrets on the other hand will allow your axles to drop down further meaning that you will also need extended brake lines and bump stops.
Hope that makes sense.. dunno how to explain it properly.
Glyn Dog Sheep
Post #56309 2nd Feb 2011 9:36pm
K9F
Thanks Glyn, I was thinking (probably misguidedly) that shorter turrets for the front and spacers for the rear would have been the best option for me! Need to speak to other experts face to face I think! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #56312 2nd Feb 2011 9:53pm
BigMike
K9, the thing with it seems to be that each and every truck, even the same model can be different in terms of prop angles. If you read that thread on the aussie lro forum (someone posted up a link earlier) you ll see the difference in measurements. There is defintely a lot of balls talked about lifts, so if you do go ahead with it, go to someone who really knows geometry and has seem all the problems before on other trucks.
Bear in mind too that your rear wheel arch is actually lower to the ground than your front wheel arch. If you lift the vehicle until the gaps from the tyres to the arches are the same, then you ve lifted the back at least 2 inches MORE than the front. In other words, it should actually APPEAR like its sitting lower at the back anyway, but the reality is that it isnt. The net effect of my springs is 1" on the front and 3" on the rear. When its under load the rears compress and the truck is level, when no load, the back appears to sit level, but actually, its a little higher. Not like a dragster, but the tape measure doesnt lie.
Post #56313 2nd Feb 2011 9:56pm
Glynparry25
Good plan Thumbs Up .... But might be an idea to run it by the forum before you spend any money. There are to many companies out there who just want you to buy what they tell you to, and make up stoopid reasons why you should.
I am going for Gwyn Lewis because of their reputation and when I spoke to him he would rather sell you what you want than tell you what to buy (unless you were to ask him to). Shame he is so far away from you so you can't drop in.
Glyn Dog Sheep
Post #56316 2nd Feb 2011 10:02pm
fekete
Give Gwyn Lewis a bell he his your man and he will give you the time and explain it to you if he is busy he will bell you back...as said i was there for over an hour and he was under my landy with a tape measure and told me what i could and could not do..and sorted my landy out...i was there to buy stuff from him and came away empty handed he will not make money on you for the sake of it Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #56318 2nd Feb 2011 10:18pm
leeds
Bournemouth to Warwick 2 hrs 40 minutes. Gwyn is supposed to be there on 13th Feb, so you can talk to the man, face to face
Brendan
Post #56332 2nd Feb 2011 10:48pm
Page 4 of 4 <1234
