![]() | Home > Maintenance & Modifications > Advice on 'lifting' the vehicle by 2" |
The Heavy Duty set up supplied with the early XS models is great in my opinion with no roll or wallow in extreme driving conditions and as such do not deem it as ![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 ![]() ![]() |
Ive got standard shocks and fitted OME springs, lifted the vehicle by approx 2" and never had an issue, if you have HD shocks you probably have similar results.
If your going for a further lift on top of that i would look into it carefully as suggested above, TBH most of us just do the odd bit of laning/Expedition stuff so i only fitted the springs due to a heavy winch bumper/roof rack/roof tent. Unless your building a challenge truck i wouldnt bother. You cannot teach stupid people to do clever things |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2505 ![]() ![]() ![]() |
Bear in mind that the distance between the axle top and bump stop are different between 90-110 and 130. Being the 130" with the most followed by 90".
On a 110" the front propshaft has 6º rake making a work angle of 12º between the prop and Tcase (which is a lot for a std UJ) and about 6º working agle respect to the front diff. Add also those 3º between the diff and Tcase flanges as the former stands to the right compared to the Tcase (reason for out-of-phase yokes at 30º). Defenetly you can not use a std propshaft on a lifted 110". Anyway, I´m still not sure how come the axle-bumstop distance is so different between 90-110 and 130s, having all the same bumpstop part number. So, whatever lift the castor angle will change and most important the diff-prop angle also. For the moment I have 0º castor ( over 3º std) and no probs with steering. Puma 110" SW ............................................................. Earth first. Other planets later Last edited by MK on 2nd Feb 2011 1:17pm. Edited 2 times in total |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 ![]() ![]() ![]() |
obviously you haven't tried any other set up......Shocks / springs.....if you had you would say the same ? Also i never put my head in the sand i sort advice of gwyn Lewis he spent a good hour with me going through everything ![]() |
K9, why do you want a lift?
Karl, here - open turrets to save messing about in future
![]() Click image to enlarge and cranked arms ![]() Click image to enlarge |
As mentioned I don't need to try any others as I am happy with the original heavy duties, the vehicle drives like it's on rails and well you know it! The lift is a desirable addition not a necessity and the decision has been made to 'place it on the backburner' until I have sufficient funds to do the job 100%, dependant on advice given here! Of which there has been lots! Many people run on standard set ups and a 'throwaway comment' like they're ![]() Treat every day as if it is your last....one day you will be right!! |
It was not a throwaway comment' as you put it... as said until you have tried a different set of springs and decent shocks how can you compare....and if you did put a decent set of shocks on i think you would eat your words.... standard shocks are
![]() ![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
STILL
![]() ![]() ![]() ![]() That's why every one changes them as soon as they can ? NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY Last edited by fekete on 2nd Feb 2011 1:34pm. Edited 1 time in total |
Cheers Mike ![]() |
I don't think the standard shocks are bad to be honest. I just found them a bit soft for what I do with the truck and the kind of ride I wanted. I think a lot of people are quick to change them because others do rather than a real need to change them. That's not aimed at anyone here by the way - let's face ir, we use thus forum because we are enthusiasts and want the right set up for us as individuals.
There is a difference between getting lift as a side effect of stiff springs, and simply "wanting a lift". If the former then it depends on what you do with your truck, and if the latter, then that's cool but for me, I would question why a lift is something actually wanted when it can lead to other issues which the warranty would be unlikely to cover in the event of component failure. If it's for greater ground clearance then taller tyres are needed as well, and unless its for competition reasons, I can't quite get my head around why a lift is actually something desirable as a lift for the sake of it, but we all want different things grom our trucks. |
is that what your misses says Karl ![]() 1968 1/32 scale Britains 109 Pick up. |
Thats on a good day
