![]() | Home > Maintenance & Modifications > Sealing a safari snorkel properly |
| alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513
I thought it was sealed as standard. So long as you fit the safari as directed, it should be good to go, no? (I have the mantec one). One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
| fordy103 Member Since: 22 Dec 2010 Location: preston lancs Posts: 85
was more on about the pipe from the snorkel to the airbox, and do you have to seal the airbox aswell? because the pipe from the snorkel to the airbox is a bit weird, as you've probs noticed, might just replace it with some sort of samco/ducting would be ALOT easier to seal
Opinions? |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2503
I did seal the airbox and around the snorkel and fender. There at least two more draining points between the airbox and the airfilter box. In my case I used a Td5 type as it was easier to chop the bottom of the snorkel to fill up the holow end (too much head loss).
Anyway you can find proper instruction on the safari web page. ............................................................. Earth first. Other planets later |
| double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573
i thought it was just a case of silacone sealent on the joints, but what i would like to know is how do you guys get around the drainage holes under the air box? because if you seal them any air born water will just build up in the air box?
any thoughts. |
| willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789
You could add a valve which can be closed for deep fording, how do you get round the Land Rover full of water up to your knackers,
110 HCPU Tipper |
willy did you not know land rover has sorted all the water leaks in the puma,
they made the heater good enough to dry you out |
The airbox is high volume, so a bit of water will do no harm. Even more a bit of moisted air increases its density. Puma 110" SW ............................................................. Earth first. Other planets later |
thanks, MK
| Martin90 Member Since: 12 Feb 2010 Location: Abu Dhabi Posts: 19
If everything is sealed properly then the amount of water that will ever make it into the airbox should be negligable, when comapre to the size of it as previously stated.
A few pics of where I sealed when fitting mine, apologies for the low quality of the pictures, camera phone in a darkish garage: Click image to enlarge Click image to enlarge I also did the drain on the airbox in the same manner but no photo! Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge It wasn't as messy as the photos suggest, honest! Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated 1989 90 - Truck cab, Mazda 35 SLTi engine 2009 90 - Station Wagon |
