Home > Maintenance & Modifications > Sealing a safari snorkel properly
fordy103
2010 Defender 90 Puma 2.4 HT Zermatt Silver
Was wondering if anybody had a link on how to seal a safari snorkel properly on a puma??
James
Post #55956 31st Jan 2011 10:05pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
I thought it was sealed as standard. So long as you fit the safari as directed, it should be good to go, no? (I have the mantec one). One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #55963 31st Jan 2011 10:50pm
fordy103
was more on about the pipe from the snorkel to the airbox, and do you have to seal the airbox aswell? because the pipe from the snorkel to the airbox is a bit weird, as you've probs noticed, might just replace it with some sort of samco/ducting would be ALOT easier to seal
Opinions?
Post #55978 1st Feb 2011 12:21am
MK
I did seal the airbox and around the snorkel and fender. There at least two more draining points between the airbox and the airfilter box. In my case I used a Td5 type as it was easier to chop the bottom of the snorkel to fill up the holow end (too much head loss).
Anyway you can find proper instruction on the safari web page. Thumbs Up Puma 110" SW
Post #55982 1st Feb 2011 1:28am
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
i thought it was just a case of silacone sealent on the joints, but what i would like to know is how do you guys get around the drainage holes under the air box? because if you seal them any air born water will just build up in the air box?
any thoughts.
Post #56017 1st Feb 2011 3:39pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
You could add a valve which can be closed for deep fording, how do you get round the Land Rover full of water up to your knackers, Censored in through the heater, door seals and numerous holes in the under seat boxes. In the uk I'd probably find a way round the water, in the outback or SA it's a different situation I suppose. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #56026 1st Feb 2011 4:16pm
double cab happy
willy did you not know land rover has sorted all the water leaks in the puma,
they made the heater good enough to dry you out Laughing
Post #56028 1st Feb 2011 4:30pm
MK
any thoughts.
The airbox is high volume, so a bit of water will do no harm. Even more a bit of moisted air increases its density. Puma 110" SW
Post #56030 1st Feb 2011 4:45pm
double cab happy
thanks, MK
Post #56031 1st Feb 2011 4:48pm
Martin90
United Arab Emirates 2009 Defender 90 Puma 2.4 SW Stornoway Grey
If everything is sealed properly then the amount of water that will ever make it into the airbox should be negligable, when comapre to the size of it as previously stated.
A few pics of where I sealed when fitting mine, apologies for the low quality of the pictures, camera phone in a darkish garage:
I also did the drain on the airbox in the same manner but no photo!
It wasn't as messy as the photos suggest, honest! Embarassed :oops:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Martin
1989 90 - Truck cab, Mazda 35 SLTi engine
2009 90 - Station Wagon
Post #56884 5th Feb 2011 12:14pm
