![]() | Home > Maintenance & Modifications > Roof Spot lights and A bar spots |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472 ![]() ![]() ![]() |
Yes, I've fitted loads over the years. If you want it switched from the front you are supposed to use an illuminated switch. Remove the trim and run the cable up the windscreen pillar, remove the fir tree fasteners along one side of the front headlining and run the cable along the hardtop gutter and continue in a similar way until you get to the rear. Presuming you are fitting the lamp in the roof panel above and to the side of the rear door - remove the fir tree fasteners and grab handles and remove the back trim panel above the rear door. Drill holes, fit lamp, connect up, earth, refit trim and Bob's your uncle. I've just fitted one (RTC8921AA) to my USW but have taped into the existing supply behind the rear, right speaker housing, ran the cables behind trim up and over the rear door to a switch which I have fitted in the L/H trim panel which is easily accessible from the rear door. The lamp itself is fitted top right of the L/H rear hardtop panel (not the roof as I didn't want the lamp above the roof-line. Recent thread on worklamps here = http://www.defender2.net/forum/topic5022.html Steve. Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584 ![]() ![]() |
Alan one of the biggest problems with the majority of lights on the market is the way they advertise/sell them. What the hell has the power consumed by the light (watts) have anything to do with the light output (lumens) or light intensity (lux) Some of the few out of a myriad of lights that give the light output are Light Force and Vision X. LED lights go from sub £50 to several thousand £. There are many lookalikes as well The LED worklights on the back of our black 110 ![]() Click image to enlarge Rated at 1 watt, don't ask me what light output is as I can not/do not know a figure. We have two on and they are great for camping/reversing by and have minimal current draw. A friend of mine has one of these Vision X 10 watt light as a reverse light ![]() This light has 900 lumen light output. More details HERE The GENUINE Vision X light is about £85-90. There is a Chinese knock off which is about £75-80. Durite are doing an extremely similar one for about £99. Prices and quality on ebay go all over the place ALan if you get to any of the shows you are welcome to have a good look at the lights on our trucks. HTH Brendan Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Paul_1978 Member Since: 08 Nov 2009 Location: South Yorkshire Posts: 384 ![]() ![]() ![]() |
I have the round type of light Leeds (Brendan) has on the rear of his 110.
Excellent little light, I got mine off ebay for about £40 i think. |
Fitting a blocking diode is quite common ![]() |
18stone Member Since: 16 Dec 2010 Location: Mid Essex Posts: 137 ![]() ![]() ![]() |
Thanks Ken. Very reassuring. My man was a bit flumoxed that it had happened but sounded confident in his proposed solution.
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
18st, who are you using out of interest?
SEB, Jon Norman at Brunel Performance in Tollesbury (Essex marshes). D300 HSE 110
Hmm. There are problems in advertising any light in lumens. The issue is that the area to be lit can vary hugely. It's actually lux and flux which are the important measurements of a lights intensity as opposed to lumens. Watts or joules are a very useful measure since if you know the power output that can be a reasonable indication of what kind of lux you're going to get. The only reason that light power is now advertised in lumens is due to yet another stupid EU law which about emissions which tries to get away from wattage as a measurement. The important figure is the radiant flux given by a light as opposed to the luminous flux from which is derived "lumens". Luminous flux is basically just how the eye sees light, it's not actually an accurate measure of the light fall itself. That's not to say that a 1 watt LED won't be bright, it may well be, but its the radiant flux which is important or how far that light falls and with what kind of intensity. eg a worklight on the back of a vehicle does not need a huge lumen output. what it needs is a decent radiant flux. However, I've found that putting the transfer box in neutral and the main gear in reverse gives a decent enough light to work with assuming the engine/ignition is on. If not then a worklight is obviously more appropriate but realistically there is little point in getting carried away with buying lights which throw out many lumens. Your mates 900 lumen light for example - a worklight can get away with being 20 lumens only and still be highly effective. A 60 lumen LED light (like those found on the better spec petzl headtorches) will give significant light and decent radiant flux. In fact my petzl will reach over 100 metres in total darkness with no problem at all, and it's radiant flux is significant. A further issue is that the marketing people in various light manufacturers have really seized on the term "lumens" and in the same way as retail camera manufacturers promoting more megapixels = good, less megapixels = bad, the light firms are doing the same. It's highly misleading the consumer unfortunately. confused? ![]() |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
fantastic ![]() |
