Home > Maintenance & Modifications > Can this be repaired / re welded
shazzy90
Post #550055 20th Jul 2016 7:07pm
Riccarton
Scotland 2012 Defender 90 Puma 2.2 HT Zambezi Silver
Yes! Talk to a local engineer / fabricator about aluminium welding and they should be able to sort it no problem. Thumbs Up
Post #550057 20th Jul 2016 7:14pm
Yes it could, but it won't be worth it. It's tired. I'd say buy new.
Post #550059 20th Jul 2016 7:15pm
BigRuss
But be prepared for the full extent of the weld failure that NDE will identify Russell
2011MY 110 XS USW Black
Post #550063 20th Jul 2016 7:45pm
Likeomg
where abouts on tyneside? i think i have one in reasonable condition..?
or is that a uprated one thats failed?
Post #550087 20th Jul 2016 9:10pm
Riccarton
It should only cost £20 - £30 to get it welded once removed from the vehicle.
As the boost comes and goes these see stress and strain that will find any weakness - such as a poor weld. If this is all it is then a decent weld should solve it long term. Yes, it has fatigued, but the image isn't clear enough to determine the quality of the original weld. For the sake of £20 or £30 I'd get it repaired first berfore spending big bucks.
Remember to flush it out well after repair - just in case Thumbs Up
Post #550102 20th Jul 2016 10:26pm
shazzy90
it is a uprated one ,I would change it for standard,but I am worried a standard one will not suit the remapped ecu,but I am open to any advice on this matter
Post #550114 20th Jul 2016 11:09pm
Likeomg
depends on the map i guess, ive got the alive ultimate intercooler if your looking for one that wont cause any more issues... welcome to come have a look,
re the map, you could get them to adjust it for not having a big intercooler till you can acquire one?
Post #550120 20th Jul 2016 11:38pm
Caterham
I think the cost difference between new and a repair needs to be considered against the hassle of fitting.
I'd be well miffed if the cooler failed again after just a few months of refitting.
good luck which ever way you decide to go.
Thumbs Up
Post #550160 21st Jul 2016 9:21am
