![]() | Home > In Car Electronics > Defender 90 300Tdi instrument warning lights not working |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 ![]() ![]() ![]() |
Probably a poor earth/ground connection? Jeff
Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
The Hulk Member Since: 13 Apr 2016 Location: Aberdeenshire Posts: 81 ![]() ![]() ![]() |
There's a multi-plug in the engine bay which carries many of the warning light wires (see the first page of the ongoing thread in my signature). I had no handbrake or brake-wear warning lights showing when I turned on the 'ignition', despite the bulbs being good. I assumed the handbrake microswitch was duff but once I got a meter on it, I realised it was working too. Tracing the individual wires is a pain when they disappear into the loom but if you have a bulk of lights failing it might just point to that multi-plug being disconnected?
Welcome to the forum btw ![]() Ongoing thread: http://www.defender2.net/forum/topic45697.html 110 300Tdi Utility (Hulk) 90 300Tdi SW (GF's Tank) |
this may help
![]() Click image to enlarge ![]() Click image to enlarge |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6691 ![]() ![]() ![]() |
Check the earth connections to the warning lamp pack. The two you can see working do so because they are not earthed at the instrument pack.
quantumfoam Member Since: 20 May 2016 Location: Newcastle Upon Tyne Posts: 12 ![]() ![]() ![]() |
Sorting out the earthing has solved all the problems on the warning lights except one. So thanks for the help its much appreciated including the wiring diagram.
Which one?
The L/R indicators warning lights don't flash although the tow warning light comes on once when the first L or R indicator is used. I can live with this as I don't use the tow point and the actual indicators are working but if you have any ideas they will again be gratefully accepted.
I bought the Land Rover as knowing it would need constant work and am retired so it was something to keep me busy. Proving to be an interesting challenge which I don't mind and am up for it LOL |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5135 ![]() ![]() ![]() |
Check to see if all the wires are Ok on the hazard warning light switch. I had a similar problem and traced it down to that switch. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Checked the wires at the back of the switch and one of the black wire spade connectors seemed loose so fitted a new spade connector pushed it on and the indicators now work fine. You guys are magic thanks a lot saved me a lot of electrical heartache
Lets see your motor sometime.
From Geordie in exile. ![]() Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
![]() Click image to enlarge ![]() Click image to enlarge This is the beast although my granddaughter has nicknamed it "Hot Wheels" |
Nice, lots of toys. Jeff
