Home > In Car Electronics > Defender 90 300Tdi instrument warning lights not working
quantumfoam
United Kingdom 1998 Defender 90 300 Tdi HT Baltic Blue
I have recently purchased a Defender 90 300Tdi 1998 and the only warning lights that work are the engine oil and battery. All the others do not work even though the actual items work (e.g. indicators side lights, main lights etc.
I have continuity checked the fuses in the engine bay and those inside the cabin (AMR5718) and all seem OK. I have also had the warning light module out and checked each of the bulbs and they all seem OK.
My next step is to voltage check the wires in the two clip in wiring harnesses that attach� to the warning light module to see if when the ignition is turned on there is a voltage to each of the bulb placements especially the glow plug one as I expected that to light up then go out.
Anyone have any bright ideas about something simple I am missing or have fixed a similar problem
Post #543007 24th Jun 2016 2:23pm
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
Probably a poor earth/ground connection? Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #543074 24th Jun 2016 6:07pm
The Hulk
Scotland 1997 Defender 110 300 Tdi HT Aintree Green
There's a multi-plug in the engine bay which carries many of the warning light wires (see the first page of the ongoing thread in my signature). I had no handbrake or brake-wear warning lights showing when I turned on the 'ignition', despite the bulbs being good. I assumed the handbrake microswitch was duff but once I got a meter on it, I realised it was working too. Tracing the individual wires is a pain when they disappear into the loom but if you have a bulk of lights failing it might just point to that multi-plug being disconnected?
Welcome to the forum btw Cool Mid Life; Live It!
Ongoing thread: http://www.defender2.net/forum/topic45697.html
110 300Tdi Utility (Hulk)
90 300Tdi SW (GF's Tank)
Post #543231 25th Jun 2016 9:47am
dorsetsmith
this may help
Post #543285 25th Jun 2016 1:20pm
Martin
Site Admin
Check the earth connections to the warning lamp pack. The two you can see working do so because they are not earthed at the instrument pack.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #543295 25th Jun 2016 1:54pm
quantumfoam
Sorting out the earthing has solved all the problems on the warning lights except one. So thanks for the help its much appreciated including the wiring diagram.
Post #543837 27th Jun 2016 12:11pm
Martin
Site Admin
Which one?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #543838 27th Jun 2016 12:13pm
quantumfoam
The L/R indicators warning lights don't flash although the tow warning light comes on once when the first L or R indicator is used. I can live with this as I don't use the tow point and the actual indicators are working but if you have any ideas they will again be gratefully accepted.
I bought the Land Rover as knowing it would need constant work and am retired so it was something to keep me busy. Proving to be an interesting challenge which I don't mind and am up for it LOL
Post #543877 27th Jun 2016 3:05pm
gilarion
Check to see if all the wires are Ok on the hazard warning light switch. I had a similar problem and traced it down to that switch. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #543880 27th Jun 2016 3:11pm
dorsetsmith
Post #543882 27th Jun 2016 3:21pm
quantumfoam
Checked the wires at the back of the switch and one of the black wire spade connectors seemed loose so fitted a new spade connector pushed it on and the indicators now work fine. You guys are magic thanks a lot saved me a lot of electrical heartache
Post #544128 28th Jun 2016 11:52am
jeffersj
Lets see your motor sometime.
From Geordie in exile. Thumbs Up Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #544141 28th Jun 2016 12:26pm
quantumfoam
This is the beast although my granddaughter has nicknamed it "Hot Wheels"
Post #544184 28th Jun 2016 2:34pm
jeffersj
Nice, lots of toys. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #544189 28th Jun 2016 2:50pm
