Home > Puma (Tdci) > Crunching Noise And Traction Control Light Flashes
schuee
Good Morning,
I was wondering if anybody could shed any light on an intermittent problem I have been experiencing on and off for a short while, sometimes when engaging 1st gear when pulling away a get a brief crunching noise from transmission, and at the same time the TC light flashes with it, then goes out and all seems to be fine, just a note it has happened also when selecting reverse gear, same symptons. It seems to be happening on a more regular basis at the moment, not sure if it is related I seem to have more than the usual backlash in the transmission at the moment, which I mentioned to my dealer, and they said their technician had indicated it was within LR tolerances.
Thanks in advance.
Keith
Post #542313 22nd Jun 2016 10:27am
Browny90
United Kingdom 2004 Defender 90 200 Tdi SW Stornoway Grey
sounds like shaft splines worn or possibly even a broken shaft..
I've had them shear in such a way that you can still drive through them until under a lot of load.. so pulling off in 1st gear the shafts will be under the most load..
I guess it must be on an individual axle/ wheel and not gearbox related.. if it was the gear box I don't thing the TC light would light up.. (I could be wrong), but assuming they use the ABS sensors and if one wheel moves at different speed to the others it lights the TC light?
certainly worth pulling out the rear shaft (as they are the easiest, then, maybe try it on a hill with and without the diff lock in, its always good to try and control a problem so you know exactly when its going to happen, this can help narrow down the options..
Good Luck and let us know how you get on. My 1986 90 is currently on a full rebuild, with new chassis, Paint etc.. Very much a hybrid, TD5 Chassis, tub & bulkhead with a 200TDI and LT77 GB Painted in Stornoway Grey Smile 2 years off the road, but getting close to completion now
Post #542319 22nd Jun 2016 10:38am
Browny90
re reading your post, are you sure its not just the noise of the TC working? they can make an odd noise while the TC is operating.. find a slippery grassy hill and test, leave it in high range no diff lock and test your TC.. My 1986 90 is currently on a full rebuild, with new chassis, Paint etc.. Very much a hybrid, TD5 Chassis, tub & bulkhead with a 200TDI and LT77 GB Painted in Stornoway Grey Smile 2 years off the road, but getting close to completion now
Post #542320 22nd Jun 2016 10:40am
schuee
Thanks for the quick reply Browny90 Thumbs Up
I will give it a try mate and let you know, I have only noticed it when driving on tarmac,
Thanks for the advise.
Post #542322 22nd Jun 2016 10:45am
hornet
Re: Crunching Noise And Traction Control Light Flashes
schuee wrote:
Good Morning,
Keith
Exactly the same with me (and others). No explanation available, but mine does it occasionally but regular from the beginning. But no faults or other issues related to that...
Post #542342 22nd Jun 2016 11:47am
Rashers
When the Defender Traction Control is working (correctly) it does make a real nasty sounding grinding noise. It was one of the things which was highlighted on the half day Land Rover Experience. I am glad it was pointed out as I would have probably thought the thing was broken. Possibly why they highlight it. Saves the Dealers after sales department all the hassle of explaining there's nothing wrong.
Post #542347 22nd Jun 2016 11:57am
Roy5695
check for chaffing of cables, especially the ones that come from the wheel sensors, this would short out and activate the ABS. Theres been a few cases of this, the loom runs underneath the vehicle on the passenger side.
Post #542424 22nd Jun 2016 3:12pm
I doubt it is any form of driveline spline failure since TC cannot help you drive out of that.
Post #542425 22nd Jun 2016 3:13pm
SimonDavies
Wales 2010 Defender 90 Puma 2.4 HT Zambezi Silver
Intermediate shaft splines worn?
When I would select 1st and pull off I would have a grinding noise. I would only have the same noise when I selected reverse and spun the shaft the other way. As time went on, this got much worse where any forward gear after a change would grind and you would feel it. Eventually it went completely - no drive.
Just something to think about.
Post #542539 22nd Jun 2016 8:56pm
jst
if it is just TC working i would question why its coming on on pulling away anyway.
broken CV or shaft is my guess.
does it off road much, large tyres? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #542546 22nd Jun 2016 9:08pm
Pinky
England 2011 Defender 110 Puma 2.4 DCPU Baltic Blue
I had this after the dealer renewed one swivel seal. Pulling away normally would initiate the TC coming on, took it straight back and it was simply that he had dislodged the wheel speed sensor, only by a fraction but it was enough. He re-seated the sensor and bingo! Back to normal.
Post #542645 23rd Jun 2016 8:11am
schuee
Thanks everyone,
Hopefully with all your advice I will be able to resolve this.
Post #542870 23rd Jun 2016 11:43pm
jst
any joy? sounds like one up^ Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #543821 27th Jun 2016 11:06am
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
I was also getting the TC light flickering and associated crunching noises occasionally on my Td5 90 when I first got it, mainly at low speed on a bumpy road, the odd thing was though that the radio would momentarily go off at the same time, turned out to be nothing more complicated than a loose earth connection on the bulkhead (loose securing nut) where they both share a common earth point.
Post #543829 27th Jun 2016 11:45am
Caterham
And where exactly would the equivalent earth be on a tdci?
thanks. Thumbs Up
Post #543836 27th Jun 2016 12:10pm
