Home > Camping, Caravanning and Holidays > Sankey MkII Trailer - My refurbishment starts
Page 4 of 9 <123456789>
Stacey007
Taking the hub off...
Ok its been a long long time since I've services hub brake....
On the hub face there are 3 screws and I've undone these, is anything else bar rust holding the hub on or should it eventually wiggle off...
Thanks
Post #520659 3rd Apr 2016 9:05pm
xpertoftheseas
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Aintree Green
If the drum is old and worn heavily, the lip created on the drum could prevent the shoes from passing as you pull the drum off. If there is an adjuster, back it off as much as possible. If there isn't one, make sure the master cylinder has no pressure on it at all and try to pull it back as much as possible, as this will pull the slave cylinder back in as far as possible, hopefully bringing the shoes with it.
Failing that, a piece of 2x4 and a 10lb tapometer usually does the trick.
Nice paint job... looks much better. My 10th Land Rover, but my first Defender.
Post #520695 3rd Apr 2016 10:27pm
Stacey007
Had a spare hour this evening in between making packed lunches for the kids tomorrow and cooking dinner...
Watched a few you tube clips in preparation.
Wheel wire brushed, sanded down, cleaned and then ready to spray.
Started with this.
then primer
then 1st coat black
2nd coat.
I will give it a 3rd coat tomorrow but I'm happy with the results given never ever done this before. I have new tyres to go on also. My plan maybe to fit alloys but thought I might as well make these smart anyway.
Given less than an hour for the wheel pleased with that.
Post #521299 5th Apr 2016 8:29pm
Stacey007
OK, Have managed a little time in the garage, in between back from a lovely holiday and starting back at work
Decided for now not to go the alloy wheel route as my new moto Keep the Sankey simple however I wanted to sort the hubs in case I do in the future. So thought about this... and came up with a solution (I think)
5mm steel plate fitted the gap I cut off.
Then as I cannot weld needed an option to hold it in place, so interweb came in handy. Special glue Smile after sanding down the edges fitted the plate. Then had bought some center caps and had to cut the tabs off the back.
Wanted to have a quick look what it looked like so loosely fitted the wheel.
I'm pleased with this Smile should look even better with the 5 small bolts painted and new Tyre on.
Then a little bit more painting and sanding the tub down... ooh and I've taken the reflectors off to sand behind.
Have to say I'm quite enjoying this Smile
Post #524829 17th Apr 2016 8:11pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Nice progress, but aren't your wheel nuts on backwards? 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #524836 17th Apr 2016 8:44pm
Stacey007
Quite possibly
Smile I only wanted to see what it looked like so didn't even tighten them, it was just to hold the wheel.
It back off now ready for the new tyre.
Good spot Very Happy
Post #524839 17th Apr 2016 8:47pm
Stacey007
Not much time spent on the Sankey, got some projects on in the garden requiring my time Smile
Anyway managed to get one of the wheels fitted with a tyre matching my truck, bit disappointed even though its a trailer wheel they scuffed the edge a bit. Looks much better though given I sprayed it.
Then managed to angle grind the other carrier off the hub on the other side, messy job but I've done the other side and it looks ok so will be ready if I do fit alloys.
plodding on Smile
Post #528852 3rd May 2016 7:55pm
keith
Good work , looks lovely. Don't forget your nuts Whistle
Post #529103 4th May 2016 5:35pm
Stacey007
I've swapped my nuts round the correct way Shocked
Smile
I'm still worried about having ago at painting (spraying) myself.... never sprayed anything before the steel wheels on this sankey.
I guess nothing to lose, I can always get it blasted and someone else do it....
Post #529135 4th May 2016 8:19pm
keith
Does it have to be sprayed ? I s 2 or 3 coats by roller not good enough ? It's a thicker , neater more robust finish in my view.
Post #529136 4th May 2016 8:23pm
Stacey007
Hello
Good call, I'm not sure...
What paint would you recommend?
would you spay primer it first though?
Post #529144 4th May 2016 8:38pm
Stacey007
Very little to update,
Got the other Tyre swapped for a Continental matching the car, was funny as I left it with the tyre place and collected it later. Came back and a different guy there, I said " I come to collect the trailer wheel'. Off they go looking for it and look confused then I spot it leaning on the wall. So said 'thats it over there' he looked at it and looked at me, A Trailer? he said...
Yes its an ex army one, not a normal garden tip one Smile the wheel / tyres was probably the biggest thing in the workshop !
So tonight job fit the 5mm plate on the hub. The tomorrow spray it and fit the wheel center.
Post #532153 16th May 2016 8:53pm
Stacey007
OK little bit of painting today after much sanding.
Its not perfect but its in keeping with the trailer and better (for me than the Nato green)
Took the front and rear reflectors off, that was fun they didn't want to budge.....
Then finished the hub for the other side, sprayed and center cap on (on and messing about with a snow cowl..)
Might have a go at roller painting the inside of the tub soon as that will be a good indication to if I should have a go at spraying the outside or rolling it...
Post #533465 21st May 2016 6:59pm
Stacey007
OK in between rain showers and I really need power (lights in my garage) even during the day its gone so grey its hard to see.
Tried spraying the rear tailgate on the inside.
Not sure I'm happy spraying and also I think the finish is Harder (is feels more robust) painted so think I'm going to try and roller paint with a small roller brush.
I've started doing the trims and awkward bits by hand.
Then I fitted the center cap to the other wheel, looking smart now with normal tyre and newly sprayed wheel.
Had a quick practice hand painted the front square to see how it looks, Actually looks ok but think a roller is the way forward and a few coats.
need to think maybe about mudflaps / guards as the wheels do stick out a bit (std steels) no spacers.
Post #533814 22nd May 2016 8:48pm
Lancerdoc999
what primer and paint have you used? I used bog standard Halfords primer and the rust started to come thru after a while. I guess if you are overlaying this with rust treating paint like hammerite etc should be ok. I'm onto my tub now. 2-3 coats of zinc oxide and first coat of satin black Hammerite but painting it on with brush. Doesn't go on terribly well with first coat but hoping subsequent coats apply better. Have got a small roller as well to try applying to larger flat areas.
Post #533819 22nd May 2016 9:05pm
