Home > Maintenance & Modifications > Roof Spot lights and A bar spots
Page 2 of 7 <1234567>
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
thanks Glyn, thats great news - looks like i'm going on a road trip
Post #52132 10th Jan 2011 12:56am
mse
nicks wrote:
hi MSE, no its Yarnolds (sorry Guy Salmon, Stratford Upon Avon)
when i first got the puma I gave him a call and tha parts manager (this is where i get my microcat cd's from) The tec said that the Td5 engine and body wiring looms were completly different to the puma and as such the sopt lamp kit wiring was different and they didn't sell it seperatly !
if there is a kit i'm going to drive up there and kit his arse !! it'll be worth the 100+ miles
I know most of them up there - his name escapes me - but i know him through LRJ connections and a friend. They havent always been too hot on their parts system (took them a week to find a part for me on it as an example and then it was wrong! took me 10 minutes)
I wont hold it against you...Guy Salmon cov or stratford isnt north warwickshire Thumbs Up
As for the kit...he is right the kit is part of the driving lamp kit but was avaliable seperately.
Its not too dissimilar to the TD5 kit...in fact get a late TD5 kit and it will work.
One difference is routing for the wiring, which (if you follow the instructions) runs over the gearbox tunnel not through the bulkhead. YOu can still do it that way. Mike
Post #52133 10th Jan 2011 12:58am
nicks
Tim is the parts manager, a very good friend and carl was the tec that told me the info about the wiring.
re the north bit, i meant up north from here.
thanks for the info mse, are you local to stratford then?
Post #52136 10th Jan 2011 1:03am
mse
Yes - Just down the road.
I use Guy Salmon Cov though for the car stuff and parts occasionally them, but only usually urgent essential things. Mike
Post #52143 10th Jan 2011 8:36am
nicks
my parents used to live in a village just outside of Stratford, so know that area. I get all my parts from them.
Post #52148 10th Jan 2011 10:23am
mse
As dealers go there are a lot worse.
Good sales dealer though Mike
Post #52151 10th Jan 2011 10:45am
nicks
i used to know them all in the good old days of John Yarnold
Post #52152 10th Jan 2011 10:46am
mse
Much better when they were Yarnolds...used to know a lot of the service guys (still one i think there)...a little more "cowboyish" then but better dealers for it (if that make sense). Mike
Post #52154 10th Jan 2011 10:52am
110SEB
Is there a definitive answer to this? Do LR have a wiring kit for spots for the Puma that is separate from their spots?
I'm keen to get one too, but would rather avoid LR prices.
Post #52271 10th Jan 2011 10:00pm
mse
Just make one, using the genuine switch!! the rest is just wire a relay and a holder for £70!!!!!! Mike
Post #52275 10th Jan 2011 10:19pm
Glynparry25
Right chaps,
I have re-traced my steps. The kit that fits is the STC 53208 (Td5, 02>)
I checked the cable kit in the full setup (with lamps) and compared it to the setup with the TD5 Kit and if anything the Td5 kit is better made with more robust parts and no need to cut into your vehicle loom which is what you have to do with the full kit.
I am uploading the pictures now and the measurments are as follows:
Y junct to battery box cable: 150cm
Y junction to Switch: 70cm
Y junction to main beam wire: 190cm
Y Junction to spot lamp plug joint: 150cm
I will be fitting it like the Td5 instructions too as I have fitted a under cubby box safe so can't feed the switch/main beam wire through that way which it describes in the instructions.
I also have the fitting instructions for both kits (I will be using a combination of both) on pdf format if anyone wants me to email it through to them.
Still uploading so will post this, go for a coffee and then put the pictures up Thumbs Up
Glyn Sheep
Post #52288 10th Jan 2011 11:03pm
Glynparry25
Top Left is the Spot lamp plugs
Bottom is the Battery box wires
Right is the Switch and Main beam wire
Relay box wires with terminals all ready to put into relay holder
Wires that go to the On/Off switch and then a single one that extends to the High Beam wire.
Accessories pack which comes with cable ties, relay, clips, main power supply, rear of switch and chock blocks.
Switch
Yes the kit is expensive but it is VERY well made and all the hassle parts are taken out or the job (getting the right lenghts, tidying them up and having everything to fit). I am happy with my purchase.... Might be an idea to contact XJ Electronics and see if they will sell you Part 12284 direct. That is the full wiring kit minus the switch Thumbs Up
Good luck with your kits,
Glyn :sheep:
Post #52292 10th Jan 2011 11:23pm
110SEB
Brilliant post Glyn thank you. May i ask for a PMd copy of the pdf instructions?
Post #52295 10th Jan 2011 11:31pm
Glynparry25
I don't know how I could put them online.... I am a tech biff when it comes to this sort of thing. Do they need hosting or something like that?
I can attach to email though Cool
Glyn Sheep
Post #52296 10th Jan 2011 11:33pm
Happyoldgit
I removed the LR spots and wiring kit that was fitted to one of my previous TD5's and have used the wiring kit in both Puma's I've had with no problem. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #52298 10th Jan 2011 11:45pm
