Home > In Car Electronics > Td5 radio surround |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6519 |
Items 3 and 13?
Click image to enlarge 1988 90 Td5 NAS soft top 2015 D90 XS SW |
7th Apr 2016 1:13pm |
1978 Member Since: 04 Aug 2015 Location: Lancashire Posts: 519 |
I have the same problem, the bezel is held in (barely) by two wire trim retention clips at 12 and 6 o'clock, and two small metal clips at 3 and 9 o'clock. The parts you need to replace it all are below. Unfortunately you need to remove half of the dashboard to install the wire retention clips correctly.
http://www.paddockspares.com/fhf000070pma-bezel-black-radio.html http://www.paddockspares.com/fbt000020-wire-trim-retention.html https://www.lrdirect.com/EYC106690-supplie...ROVER.html |
7th Apr 2016 1:31pm |
isacs Member Since: 28 Aug 2015 Location: Leamington spa Posts: 404 |
Item 3 yes, and I'm guessing the clip with no picture from lrdirect. The wire retainers asleep to do their job ok-ish
7th Apr 2016 3:57pm |
EYC106690 is this:
http://www.roversnorth.com/files/Images/large/EYC106690.jpg 1988 90 Td5 NAS soft top 2015 D90 XS SW |
7th Apr 2016 3:59pm |
That's the bad boy!
7th Apr 2016 4:15pm |
£2.64 each inc VAT from a LR dealer before any discount you can wangle 1988 90 Td5 NAS soft top
2015 D90 XS SW |
7th Apr 2016 4:17pm |
