Home > In Car Electronics > Td5 radio surround
isacs
Td5 radio surround
Does anybody know if the plastic surround is still available? Plus the metal clips. My HU keeps popping out on the r/h side and the only thing I can see that holds it in place is a pathetic little metal clip which is broken. The surround isn't in the best shape either so I want to replace both.
Post #521858 7th Apr 2016 12:56pm
Martin
Site Admin
Items 3 and 13?
  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #521863 7th Apr 2016 1:13pm
1978
United Kingdom 2003 Defender 90 Td5 HT Belize Green
I have the same problem, the bezel is held in (barely) by two wire trim retention clips at 12 and 6 o'clock, and two small metal clips at 3 and 9 o'clock. The parts you need to replace it all are below. Unfortunately you need to remove half of the dashboard to install the wire retention clips correctly.
http://www.paddockspares.com/fhf000070pma-bezel-black-radio.html
http://www.paddockspares.com/fbt000020-wire-trim-retention.html
https://www.lrdirect.com/EYC106690-supplie...ROVER.html
Post #521870 7th Apr 2016 1:31pm
isacs
Item 3 yes, and I'm guessing the clip with no picture from lrdirect. The wire retainers asleep to do their job ok-ish
Post #521893 7th Apr 2016 3:57pm
Martin
Site Admin
EYC106690 is this:
http://www.roversnorth.com/files/Images/large/EYC106690.jpg  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #521894 7th Apr 2016 3:59pm
isacs
That's the bad boy!
Post #521907 7th Apr 2016 4:15pm
Martin
Site Admin
£2.64 each inc VAT from a LR dealer before any discount you can wangle Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #521909 7th Apr 2016 4:17pm
