![]() | Home > Puma (Tdci) > One shot grease puma defender |
tuesdayfox Member Since: 23 Jun 2013 Location: Sydney,OZ Posts: 129 ![]() ![]() |
Hi guys,
My rear brakes are both gone at 45k kms. could be due to the Traction control when offroading or something else . anyway I am planning to change the disc rotor and the brake pads. also, I am going to inspect all four wheels's wheel bearings and regrease them (convent the puma spacer setup to tdi300 adjustable setup) . and since I will remove the front wheels, I am thinking might just fill up the swivel housing too. So I bought 4 one-shot greases. and now my question is, since I cant find it in the workshop manuals. how to properly fill the swivel housing with one shot grease? like: 1, should I fill it to the rim of the filler hole? 2,does it matter if I overfill it? 3, what is the torque setting for the filler plug? thanks Martin |
thanks!
so basically its seal for life and only refill when overhauling the swivel ? |
tomdaprince Member Since: 23 Feb 2015 Location: IJmuiden Posts: 54 ![]() ![]() ![]() |
That is the general idea, but its def. worth checking every once in a while as expecting something to be just fine in a Land Rover might be risky. In mine after the first 130.000km the swivel grease just disappeared for some reason even though it did not leak out and didn't leak into the axle either.
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2028 ![]() ![]() |
No harm in filling up.
Remove road wheel and axle stand underneath for safety Turn wheel outwards to full lock (otherwise you cannot put the grease in, the swivel ball blocks the filler hole on straight ahead steering.) Undo plug and fill. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
I filled my swivels last week thinking they won't take much but to my surprise both sides took the full 375ml sachet. I'm guessing that after 5 years, 60k kms most of it has leaked into the axle tube explaining why my front diff oil is blackish when I change it every year.
Theres the usual slight weep under the swivel ball seal but I presume that as long as there's lube where its supposed to be its ok. Each sachet was only £3 from Paddocks. Not sure about torque but the nut was a miniature version of those on the differential sumps so take care not to over tighten. The sachet should come with a short length of plastic tube which you just push onto the sachet nozzle, then the other end as far into the swivel filler hole as you can before squeezing until it starts to come back out at you. Then its full ![]() . |
Hi guys.
thanks for all your input. I actually ended up using 3 sachets. (bought 4) p.s. mine is My13 110. done 50k kms. |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
I have a 20L tub of BP NLGI 000 liquid grease, is it OK for swivel housings? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2702 ![]() ![]() |
Top tip if using the one shot sachets. Stick it in a bucket of hot/warm water before you use it. It will become less stiff and flow into the housing easier. 110 D250 SE HT
110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
Simon27 Member Since: 30 Oct 2012 Location: East Lothian Posts: 131 ![]() ![]() ![]() |
Where were you on Saturday morning when I lying on the cold ground trying to squeeze the grease into my swivel! |
![]() ![]() ![]() 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
