Home > Maintenance & Modifications > Patriot or Hannibal group buy
Sign Up
(2)
(2)
User Registered Confirmed
TC7th Jan 2011 12:22am
BBSJK7th Jan 2011 11:56am
BigRuss6th Jan 2011 10:17pm
SteveS8th Jan 2011 11:16pm
Page 2 of 5 <12345>
leeds
Thanks Tack, I owe you a pint. You just saved me the job of digging a 110 rack out and weighing it.
Right a couple of points Hannibal racks are South African made and fully welded. Advantages is you don't have to assemble it, lighter then a patriot, difficult to send by courier around the countryside. Being fully welded what do you in middle of nowhere if a weld fails?
Cost for a non coated 110 one delivered with VAT appears to be £1131.60
Patriot racks are made in the UK and are a giant meccano set. Heavier then equivalent Hannibal. Easier to repair in the field
Cost including VAT and delivery is a £1,000.
HTH
Brendan
Post #51655 8th Jan 2011 12:01am
carlaac
United Kingdom 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Hannibal for me
TC - Stick me down for a Hannibal if we're going to do this.
Plenty of people praise the Hannibal and I'm confident it will do the job (Manning up my USW!). Not sure if I'd even bother with the coating, can always get it coated by a local specialist in the future if it starts to look cr@p.
Most important thing for me would be light weight, low noise and good Aero, keep the MPG.
Access Ladder also.
OoI - does anyone know if the expedition rack (like one on the 90 in the top right corner) could carry a roof tent? guessing it can't because of sides? I like the look of them and probably lighter than both Hannibal and Patriot... Ken....
Post #51678 8th Jan 2011 8:58am
BigRuss
Well I always looked at the Hannibal with the view of a Hannibal roof tent and a-wing, I know a few people that have the Hannibal racks and haven't had any problems.
All that said I would rather pump my money in the British economy rather than the south African but the weight is a big factor especially when I don't plan on altering the suspension just yet and I love the idea of a black anodised rack over powder coated.
Now I can see being able to make alterations to your vehicle in the field is a good thing but how much damage can you really do to the rack?
As the patriot rack is bolted is there any issues with the bolts coming loose/going missing???
Russell Russell
2011MY 110 XS USW Black
Post #51684 8th Jan 2011 10:23am
TACK
Your welcome brendan Thumbs Up
I honestly thought the weight would be more than that.
I got the Patriot for a good price, I had to make my own altertions to the legs as these were protype legs to go with a particular roof tent. The rack only goes on for my adventures then off again as I am not constantly able to live the life of an Raulph Finnes Rolling with laughter Therefore putting it on and taking it off is pain with the weight and I personally find the difference of vehicle charateristics between having it on are noticable. Having the rack on also always me into even less carparks too Rolling Eyes
As for repairs in the field, and I have 1% overland experience compared to brendan, most things I have read maintain a steel rack, like a brownchurch are best, for the obvious reasons of being able to weld etc, but all personal choices I suppose.
Last time I took the rack off it had the roof tent on it too, used my inlaws Barn, set up block and tackle on a roof joist and used my winch to take the whole lot off in one go, will do that again when i go to using it again Thumbs Up
Post #51690 8th Jan 2011 11:25am
leeds
I use an electric hoist to lift roof tents/rack on and off. Only slight problem is getting centre of gravity right. Ratchet straps there can help as easier to adjust. Just take some time over it.
Steel racks v welded ali racks. Probably easier to find a welder for steel in the bush then ali
Have used a Patriot rack , carry some allen keys spanners and a few spare bolts.
All three types of racks have advantages and disadvantages, steel tends to be cheaper but not so easy to walk on unless boarded out. Ali slats running front to back are preferable to those running sideways. Welded v mecanno set??
If just want to carry a roof tent why not 3 roof bars? Lighter, cheaper and easier to fit.
If you decide you don't like a Patriot rack stick it on ebay and you stand a reasonable chance of getting most if not all your money back.
Personally I am not a big fan of roof racks/tents for my own use, preferring ground tents and all my stuff inside the 110.
However different people have different needs/wants
Brendan
Post #51713 8th Jan 2011 1:44pm
discocuzzy
Both great racks, i just love the fact that the patriot is bomb proof, had mine for 4 years, originall purchased for the DC and then altered for the CSW...highly recomended Thumbs Up
There is not that much in it weight wise and i never take mine off....but i do have a fuel card! You cannot teach stupid people to do clever things
Post #51716 8th Jan 2011 2:24pm
RLD
this is one i made for a ninty RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
Post #51720 8th Jan 2011 2:58pm
AndrewS
I have 2 Hannibal racks 110 and 130. Both carry Censored loads of kit every day ladders, pipes, pumps, steel work etc etc. And both have been to Morocco loaded to the gunnel's driven across endless corrugated roads at high speed. I have never had issues with either.
Click on pictures to enlarge
The Hannibal rack for the 130 DCHCPU has no support from the back of the cab to the two rear supports. In standard form there are two hefty shaped box section legs. As J-Lo has a big back end the standard supports would not fit, so I made my own ally supports (circled in red below) that bolt direct to the top of the rear cover.
Even though the rack is not supported (see below) you can see from the pictures above there are no sagging problems.
I'm not slagging Patriot racks off here, just saying that from my own experience the Hannibal is light and will do the job Thumbs Up 130's have feeling's as well you know Smile
Post #51723 8th Jan 2011 3:23pm
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
I'm just about to buy a Hannibal 2.8m rack for my 110 USW - so would be interested in a group discount. I had in mind the type where a small stanless/ally table slides underneath the rack - and therefore not in the truck. Bit more weight up top admittedly but at least will have a decent surface for the field kitchen (or fixing the truck!!)
I intend to kit out with Hannibal RTT and side awning too.....good to get a discount there as well
Put me down for a Hannibal - but need to be quick as I want for the Spring
Nene have given me some pricing and I was just about to put a chaser into D44 for prices
Post #51887 8th Jan 2011 11:16pm
BigRuss
If you done mind me asking, what prices did nene give you? Russell
Post #51892 8th Jan 2011 11:35pm
SteveS
Prices from Nene
Roofrack is £1146 [this is the 2.8m c/w table)
1.4 Tent is £1032
Tourer Kit is £426
Awning is £504
Delivery will be approx £84
All prices are inclusive of Vat at 20%.
Post #51893 8th Jan 2011 11:41pm
Surrey Rover
To back up AndrewS re Hannibal, I had one on my last 90 hard top and abused it for many years without the slightest sign of fatigue or failure.
I bought it second hand and after I finished using it I sold it for the same price I paid for it, the same couldn't be said for the Land Rover it was attached to Big Cry
Post #51914 9th Jan 2011 8:29am
BigRuss
SteveS wrote:
Prices from Nene
1.4 Tent is £1032
Tourer Kit is £426
Awning is £504
How much are they charging you for the table?
Just had a look on Devon 4x4's website and for all that delivered (providing you've be priced for the 2.4m awing) is only £14.2 less with out the table.
Just had a look at first four off road and they are £36 cheaper than nene without the table. Russell
Post #51929 9th Jan 2011 10:20am
Zagato
TACK wrote:
BigRuss wrote:
Well I couldn#t find the weight of a patriot roof rack but according to first four offroad the hannibal only weighs 40Kg.
Just looking at the list prices from patriots website a 110 rack is £1000 + £200 for powder coating.
While having a look around on the price list I saw that they did a ladder for DC defender which also carries the weight of the back of the rack. Now I know what ever rack I have will be supported the length of the gutter either side of the vehicle, but what about using the DC supporting type ladders at the back as a way of transfering the weight of the rack and load to the chassie. Question Question
I think the best person to ask about the weight of a patriot rack would be Leeds.
I have a 2.8 Patriot for my 110, with the legs fitted, no rails, no extra fittings or ladder it weighs 52kg. How do I know this........because I just weighed it in the garden especially for you Bow down
I thought it would be more than that, if is F**king heavy. If I was buying again I think I would go Hannibal. Whistle
See her also http://www.defender2.net/forum/topic2848.html?highlight=patriot
LR say max weight on a 110 roof is 75KG - that includes any roof rack weight Thud Think it's safe to say it will take a lot more Rolling with laughter
I've always tried to keep my Landies as light as possible, I nearly bought a steering guard once until I picked it up and felt the weight of the thing - landies do enough MPG as it is..............I adhere to the mountaineering ethos of keeping weight light and low, just take what you really need. We always kipped in the back of mine, it saved on frigging around with tents and and it's the best place to be with regards to security Thumbs Up
Post #51933 9th Jan 2011 11:10am
leeds
I am sure that Hannibal racks are fine racks just like Patriot racks.
Yes there will be those people who think Hannibal racks are the bees knees others will think the same of Patriot racks.
This sort of thread should be (and is) a constructive thread to help people decide what rack is best for them
Many 4x4 items are offered for sale with limited or poor information, don't get me going about lights/jump leads etc.
Anyway back to roof racks. Yes Patriot are remiss for not publishing the weights of their racks. Today I weighed a Patriot D2 2.5m rack without the luggage rail.
Weight was 47.8 kg according to the bathroom scales down at the lockup.
Quote:
HR06 Discovery II
2.1 m
1.41 m
180 mm
35 kg
So add a fifth of the weight to the Hannibal rack to compensate for its shorter length and it would be 42kg
So in round terms the Patriot rack is about 6 kg or 15% heavier then the Hannibal.
Can that be applied across the range of racks???
HTH people
Brendan
Post #52098 9th Jan 2011 11:16pm
Page 2 of 5 <12345>
