Home > In Car Electronics > Wire up LED light bar - with main beam or separated? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19571 |
Roof bar lights need to be switched AFAIK.
Front mounted can be main beam only. |
10th Mar 2016 9:04pm |
dave18 Member Since: 11 Jul 2015 Location: Gorleston, Great Yarmouth Posts: 497 |
I've always wired mine up both. So On or on with mains.
10th Mar 2016 9:11pm |
Yes, that would be what I would do too if I had roof lights.
10th Mar 2016 9:22pm |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Except on forward control vehicles roof mounted lights are not legal for road use.
Mounted otherwise they must be switched at a point remote from the driving seat. |
10th Mar 2016 9:35pm |
dantastic Member Since: 04 May 2010 Location: London Posts: 367 |
How far away are we talking here?? So a switch 100% independent of the driving lights. |
10th Mar 2016 9:37pm |
Yes
10th Mar 2016 9:41pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
Legal position? All optional headlights, i.e. LED light bars and spot lights have to be type approved or E marked. I am not aware of any 42" LED light bars which are E marked so unless yours is E marked it will be illegal for road use. As far as I am aware there are no height restrictions on the position of optional headlights. Brendan |
11th Mar 2016 8:44pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16876 |
Can you cite a source for this assertion, please? When I finally get time to fit it, mine will be wired via a modified lighting stalk switch on the right of the column so it can either be on directly with no other lights, for site use, or off altogether, or on with main beam. |
11th Mar 2016 8:58pm |
I've no idea what the legal position is, but I can vouch for it being really annoying meeting a car coming the other direction which is rivalling Blackpool Illuminations and having them gradually turn off one by one before you can see where you're going again.
11th Mar 2016 10:19pm |
If the vehicle is pre 91 or somewhere like that then Non 'E' mark can be fitted legally. Reference the Legalitys of the roof lights its first time ive heard that especially since im sure Ford and Mercedes sell Roof Light bars for their vans!!! |
13th Mar 2016 1:36am |
HI Dave, the current UK Vehicle Lighting regulations and various amendments date back to 1989 which revokes the earlier acts dating back to at least 1984. Pre 1984???
The 1989 act speaks about obligatory lights having to bear an approval mark, but does not stipulate E marked or the old British Standard mark When the actual harmonisation of vehicle regulations concerning headlights date back to (UN ECE) I do not know, however the UK has been a signatory for 50 odd years. Brendan |
14th Mar 2016 10:41am |
yorkshireman Member Since: 28 Mar 2016 Location: North England Posts: 80 |
Hi all, I'm about to wire in a 20" LED bar to my front A-bar, so looking at this thread am I ok to wire into the high beam without the switchable option?
11th Apr 2016 7:13pm |
Yes and No.
Have a good look at the lens If there is an E mark which should be in a circle plus a double digit which represent the country which granted the approval. Now I can not remember if there should be a 4-6 digit actual approval number on it. To be road legal it must be E marked and wired through the main beam switch. I would suggest an additional switch after the main beam switch so you have can then have dipped beam, main beam and main beam + light bars. Brendan |
11th Apr 2016 7:49pm |
Thanks for the note Brendan, despite the documents I can't find a mark on the unit, it's an Aurora. To be safe I'll wire in a switch, I've a blank in the dash on my Puma, can you buy 'Aux' switches to fit?
11th Apr 2016 8:10pm |
