![]() | Home > Maintenance & Modifications > Another soundproofing thread |
redline Member Since: 28 Jun 2015 Location: Mountains and Lakes Posts: 221 ![]() ![]() |
Having spent far too much time thinking about it, it was time for action! First step was taking out all the interior, and cleaning all the glue from the carpet off the sheet metal. The last bit was a heck of a job. I can't imagine why the previous owner would have glued in the carpet... seems a very odd thing to do. Anyway, after much elbow grease, this was the result:
![]() Click image to enlarge With everything out, I used the LR water ingress manual to identify any possible leakage areas, and sealed these as per the instructions. Next was the application of the vibration damper. The roof was fairly easy, as we used the 3.5kg / sq.m material, which is fairly pliable and easy to work with. ![]() Click image to enlarge For the floor areas I chose to use the 6kg / sq.m stuff. This was harder to apply because its much stiffer (even in warm temps) and because the floor areas have contours and bends. A lot of time was spent with the roller, working out air bubbles and ensuring good adhesion. Aluminium tape was used to cover all the joints: ![]() Click image to enlarge |
The original plan would have then had me laying down the CCF and MLV where applicable, followed by a custom fit removable carpet... however... I then decided to install a rear storage box in the load area. Had I known this previously, I wouldn't have bothered with the vibration damper in the rear. Whilst the box was being made, a friend suggested lining the interior surfaces with a protective coating such as Line-X. I initially dismissed the idea, but having a few days to ponder over it, I convinced myself that actually it would be pretty neat. My rationale was that it would be a hard-wearing and easy to clean surface in instances that I am doing dirty work (under the removable carpet).
Cue much forum reading.... It seemed that some people had tried it, but I couldn't find any feedback on how to apply it, and the longevity. Before committing to doing the entire car, I decided to try some samples. We laid out a panel with a vibration damping layer, cleaned and scuffed the surface, and sprayed it with two light coats of Rhino Liner (cheaper than Line-X). The result was very positive. I tried jet washing it, scratching it and generally abusing it, and it held up very well. So I decided to go ahead and line the entire interior floor area, over the vibration damping layer. Here is a shot of the passenger foot-well: ![]() Click image to enlarge And a close up of the surface: ![]() Click image to enlarge Overall I am very impressed with the liner. Its aesthetically nicer than the underlying matt layer, and functional in that it is grippy, easily cleaned and water proof. I will now lay an MLV layer in the foot-wells and carpet on top, but which can be easily removed when I need to. Driving around (with no interior) the 110 sounds considerably quieter, and less tinny. Its by no means quiet, but certainly more bearable than previously. Once I have applied the CCF layer to the roof, replaced the head lining, and refitted the interior I am sure there will be some further minor incremental gains. All in all, I'm quite pleased with the result ![]() |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7938 ![]() ![]() ![]() |
Excellent work!
LoveTheMud Member Since: 19 Feb 2015 Location: Weybridge Surrey & Pontefract West Yorkshire Posts: 411 ![]() ![]() ![]() |
Thought you might like this to watch. I found it very interesting.
&sns=em |
Good video from Dynamat! I only take issue with them saying that Dynamat can be 10x more effective than competing products
![]() Also the bit about the coverage is misleading. Whilst it may be true that you need only 40-50% coverage to cut the panel vibration and give it that "dead" thud sound, it ignores the fact that covering the entire panel acts as a noise transmission barrier. That may not affect a cymbal hanging in the air, but in an enclosed space that is a car, it does further cut noise coming through the panel. Obviously you get to a point of diminishing returns in terms of bang for buck, but in a Defender I feel that its worth covering as much as possible. |
