![]() | Home > Maintenance & Modifications > 90HT - Load Bay Trim |
1978 Member Since: 04 Aug 2015 Location: Lancashire Posts: 519 ![]() ![]() ![]() |
Thanks very much, I'll give them a call and get some ordered. |
I wouldn't be gluing in anything until you are at least sure you have no initial built water ingress issues.
Even after that my preference would be to loose fit rubber mats that can be lifted out regularly when you want to do a deep clean or look for any water ingress issues. If you do get water underneath any of these permanent or semi permanent solutions it will accelerate any corrosion issues exponentially. There's some photos on another thread showing the horrors after peeling back someone else's handiwork. Edit: ![]() Click image to enlarge ![]() Click image to enlarge http://www.defender2.net/forum/viewtopic.php?p=502420#502420 Last edited by Supacat on 9th Feb 2016 3:16pm. Edited 2 times in total |
Ryderoo Member Since: 28 Aug 2015 Location: South Oxfordshire Posts: 1666 ![]() ![]() ![]() |
JBK, Chris@CSK did my dynamat, he then covered the side with board and carpet, he did a top job would recommend any time, 1st class job. I would take some piccys but working away at mo so not close to my 90. you will not be disappointed. Cheers Simon I can explain it to you, but I can't understand it for you 1990 110 TD5 county, my first Land Rover - gone 2012 Discovery 4 XS SDV6 - gone 2014 Discovery 4 XS SDV6 - gone 2015 Evoque SD4 dynamic - Wife’s - gone 2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone 2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24 2021 Defender S D250 Santorini Black 110 HT - gone March 24 2023 Evoque P300e SE wife’s current vehicle |
