Home > Maintenance & Modifications > 90HT - Load Bay Trim
Page 2 of 2 <12
jimbob7
....also aluminium flashing helps massively to reduce resonance on panels....but it stinks for a bit. Pov.spec,ftw. 2006, 110,TD5.
Post #502101 8th Feb 2016 1:50pm
1978
United Kingdom 2003 Defender 90 Td5 HT Belize Green
Vintagepaul wrote:
No rattling from the panels that I've noticed since fitting them.
The general noise levels from the rear of my HT are definitely lower with the mat and side panels fitted. Thumbs Up
Unfortunately I can't remember what the panels are made of but if you send an email to TGE I'm sure they could confirm what they are constructed from for you.
Thanks very much,
I'll give them a call and get some ordered.
Post #502103 8th Feb 2016 1:52pm
I wouldn't be gluing in anything until you are at least sure you have no initial built water ingress issues.
Even after that my preference would be to loose fit rubber mats that can be lifted out regularly when you want to do a deep clean or look for any water ingress issues.
If you do get water underneath any of these permanent or semi permanent solutions it will accelerate any corrosion issues exponentially. There's some photos on another thread showing the horrors after peeling back someone else's handiwork.
Edit:
http://www.defender2.net/forum/viewtopic.php?p=502420#502420
Post #502115 8th Feb 2016 2:19pm
Ryderoo
England 2015 Defender 90 Puma 2.2 HT Santorini Black
jbk wrote:
Just spoke to CSK, shopping list on its way over to him Wink Thanks for the lead on supplier.
JBK, Chris@CSK did my dynamat, he then covered the side with board and carpet, he did a top job would recommend any time, 1st class job. I would take some piccys but working away at mo so not close to my 90.
you will not be disappointed. Cheers Simon
I can explain it to you, but I can't understand it for you
1990 110 TD5 county, my first Land Rover - gone
2012 Discovery 4 XS SDV6 - gone
2014 Discovery 4 XS SDV6 - gone
2015 Evoque SD4 dynamic - Wife’s - gone
2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone
2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24
2021 Defender S D250 Santorini Black 110 HT - gone March 24
2023 Evoque P300e SE wife’s current vehicle
Post #502251 8th Feb 2016 7:54pm
Page 2 of 2 <12
