Home > Maintenance & Modifications > 90HT - Load Bay Trim
jbk
United Kingdom 2016 Defender 90 Puma 2.2 HT Santorini Black
Hi All, I have a new 90HT that i pick up in a few weeks. There's nothing in the rear but bare paint and I want to get the car prepared for putting gear (shooting stuff, bit of mud and just other blokes hobby type 'stuff') in the rear but without damaging or scratching any of the panels or paintwork. I'm a bit OCD with my paintwork and detailing so the usual hard load liner doesn't float my boat, I reckon i'd imagine it'll just be rubbing and scratching panels, storing dirt and mud underneath thus scratching and just generally not that lovely a thing to look at and live with. So, I'm thinking about having the whole of the rear interior trimmed in something that:
    protects all paint work,
    breathes,
    does not leave 'orrible v tough to get rid of glue everywhere,
    is possible to clean fairly easily if and when it does get muddy from shooting gear type use and
    does not require me drilling holes anywhere.
I know, not much to ask, and a bit of a strange OCD non typical landy kind of request I appreciate, but all the same I figure I'm not alone in wanting to really look after my wagon, whilst wanting to use at the same time.
Any thoughts and advice appreciated.
Regards
Post #501508 7th Feb 2016 12:07am
miker
I'd go with sound deadening, and some closed cell foam on the sides, along with the mud trim pieces or similar.
Then deadening, CCF and maybe ply line the load area? Or tread plate?
Post #501513 7th Feb 2016 12:27am
jbk
Thanks miker, what's CCF I wondered? Oh i should have added that I'd liek to avoid drilling so ply lining or chequer plate isn't gonna be for me. I guess really I'm looking for some nice looking, but cleanable and rugged carpeting type affair, but with adhesive that will be removable without three days of melting adhesive down with chemicals to get it off.
Post #501610 7th Feb 2016 12:31pm
miker
CCF = Closed Cell Foam
If we're allowed to receommend suppliers on here, Sound deadening shop have a wide variety of brands, prices and bulk packs.
Not sure what to recommend for your carpeting dilemna. It's difficult to attach anything when mounting holes and glue are out of the question! Double sided carpet tape would work, but that's pretty sticky as well.
Post #501623 7th Feb 2016 12:48pm
jbk
Ha ha ha, yeah not giving you much option without drilled holes or glue!! I guess what I'm asking, a question for a trimmer perhaps, is whether there is an adhesive which is easier to remove than the usual which takes hours and hours should one decide that they want to remove it. Another thought i had is possibly to line the interior with PPF, paint protection film, then the glue could go on top of that and if removal was required the ppf could just be pulled up as that'd be much easier than manually removing the glue.
Ah, CCF, got it and thanks for the recommendation on the Sound Deadening Shop, I'll check them out. I'm just in the middle of looking at those Mud 90HT sidepanels which look interesting. I bet it's a job to fit these things, and any other interior stuff, well enough that it doesn't end up resonating or rattling at certain road speeds and rpms, lots of adhesive points i guess is the key here.
Post #501625 7th Feb 2016 12:55pm
stanley
Don't have any experience of mud panels , I have TGE ins for my 110 utility , but Mud stuff is usually pretty good
Post #501634 7th Feb 2016 1:08pm
Mach1
United Kingdom 2015 Defender 110 Puma 2.2 XS DCPU Aintree Green
It's probably worth speaking to Chris at CSK in Hoddesdon. He's doing mine at the moment. 2013 90 HT
2015 110 DC
2012 FFRR
1996 Discovery
Post #501984 8th Feb 2016 8:31am
jbk
Just spoke to CSK, shopping list on its way over to him Wink Thanks for the lead on supplier.
Post #502053 8th Feb 2016 11:38am
Mach1
Thumbs Up 2013 90 HT
2015 110 DC
2012 FFRR
1996 Discovery
Post #502059 8th Feb 2016 11:53am
Vintagepaul
2015 Defender 90 Puma 2.2 HT Santorini Black
I've used TGE side panels to protect the sides and the rubber land rover mat to protect the floor and raised sides.
The TGE panels require no drilling, (just remove the seat belt hangers and they slot in behind and then refit hangers), they have a carpeted finish and were good value. I think around £110 delivered from memory.
 2015 Defender 90XS HT
Post #502081 8th Feb 2016 1:04pm
1978
United Kingdom 2003 Defender 90 Td5 HT Belize Green
Those look like the kind of think I was planning to make.... I'm tempted to buy a pair of these now! What are they made out of please?
Post #502087 8th Feb 2016 1:16pm
Vintagepaul
1978
Website link for TGE here:
http://www.tge-defendertrims.co.uk/landrov...ingham.htm 2015 Defender 90XS HT
Post #502090 8th Feb 2016 1:30pm
1978
Thank you, I had found that, but couldn't find any reference to their construction apart from 'a rigid structure'. Also interested to learn if you have any rattling issues since they only seem to have one mounting point? Thanks for your help.
Post #502092 8th Feb 2016 1:34pm
jimbob7
For the floor, rubber horse mat,easily removed for cleaning/drying,provides good sound noise insulation (nearly an inch thick).For the wheel boxes I glued 1.5mm rubber sheet,also on the sides but added ccf anorl (same for the cabin). Pov.spec,ftw. 2006, 110,TD5.
Post #502095 8th Feb 2016 1:39pm
Vintagepaul
1978
No rattling from the panels that I've noticed since fitting them.
The general noise levels from the rear of my HT are definitely lower with the mat and side panels fitted. Thumbs Up
Unfortunately I can't remember what the panels are made of but if you send an email to TGE I'm sure they could confirm what they are constructed from for you. 2015 Defender 90XS HT
Post #502097 8th Feb 2016 1:44pm
