Home > Maintenance & Modifications > Soundproofing my 90!
Page 1 of 3 123>
YOLO110
Australia
Having driven my 90 for a few thousand km, I thought it was time to make it a more pleasant environment to live with, especially with reducing the road noise! After much reading on here and other forums, I decided on a strategy, fitting Dynamat Extreme, then a mass loaded vinyl, then a quality carpet with sound deadening properties as well!
The whole lot has been work in progress for several months... I went through a phase of wanting to leave the rear seats out and just install a rear cargo drawer leaving me with a lovely flat floor! But having driven around without seats for a couple of months, the practicality of that waned and I decided to proceed with the rear seats installed!
So, first job was to remove the rear seats (heavy!) and all the associated hardware! Dynamat installed, very sticky stuff so you have one go to get it in the right place! I made templates for the forward end of the wheel wells and over the fuel filler cap. Being summer in OZ, it was lovely and sticky from the get-go, but a good hard roller ensures a nice finish!
It took 2 full packs to do the entire area, minimal wastage.
Once the dynamite was down, it was much quieter! I was very surprised how such a thin layer worked so well, stopping the panel vibrations and resonance makes a big difference!
Then came the mass loaded vinyl. Lots to choose from, but I finally settled on a product made by pyroteknc called Wavebar Quadzero. I chose the 4KG/meter version... It's only about 2mm thick and quite flexible. It offers a big jump up in sound absorption from the 2kg stuff, but is nearly as effective but is not as thick as the 8kg/meter version which was 5mm.
I use my carpet sections to mark up then cut out templates for the Quadzero. Easy to cut using a craft knife. I then used SikaFlex contact adhesive to secure this in place over the top of the DynaMat. I did this outdoors with all the windows open and a respirator mask on as this glue stinks! Again, the contact adhesive is VERY sticky so definitely a once only chance of getting it in the right place and alignment from the get-go! As a 'one man job', this was challenging as it's heavy too! One side done!
All done!
The combined thickness was now the Dynamat plus the Quadzero! Too think to re-install the seat frames to line up with the holes, so I cut around these and peeled off the Quadzero leaving just the Dynamat. This was perfect.
Next came the carpet install! I had decided to use the great product made by LRI in the UK. Apparently it is Jaguar carpet, it's certainly a nice quality. In view of the fact that I may want to remove the carpet for cleaning or access, I decided not to use contact adhesive, but rather industrial strength double sided tape to fasten it in place. Some careful measuring up using 4 lengths. Despite the self stick of the tape, it was till not enough too really stay secured to the back of the carpet, so I once again used contact adhesive to secure the tape to the carpet face.
Both sides now installed. Some very minor trimming required but otherwise a perfect fitting carpet from LRI. The only pieces not included for some reason were the wheel arch faces and the fuel filler neck. I bought a small piece of black automotive quality carpet and using the same templates I had used for the dynamat, I cut out pieces to suit and contact adhesive these in place.
The floor piece is thicker and comes with a sound deadening material backing. Once again, this fitted perfectly with no trimming required. Very impressive from LRI, thanks!
Finally, got the seats back in, heavier to re-install by myself! I finished off the job by replacing and installing the rear door 'kick strip' with lovely brushed Stainless Steel versions from Brendan at 4X4 Overland. Spot on fit and looks very smart!
Really pleased with the whole job! Not only is the Defender MUCH quieter now (my other half even commented on it!) but it looks really great too! Plans now to do the front in the same way!
Cheers, Pete Very Happy YOLO... You Only Live Once...
Post #501517 7th Feb 2016 12:43am
mk1collector
Excellent work and write up Thumbs Up Ray
My build thread
Post #501519 7th Feb 2016 1:41am
Enid_Puceflange
Scotland 2002 Defender 110 Td5 DCPU Baltic Blue
Thanks for the write up
I have two full packs sitting waiting to do the rear of my 90 HT, I was hoping it would be enough to get some of the sides done too but going by what you have managed, it looks like I'm going to need a bit of extra to get all of my back end (ooh-err) done to my satisfaction.
Then, same as you, I will move on to the front. Which will be a trickier job as my 90 barely has any carpet / sound proofing left over after years of neglect as it was originally quietened down with that glued down Horse Hair type stuff they used to use with rubber matting attached on Top.
That's all coming out too!!! Big Cry
But Cheers for the motivation. It's nice to see what it mine could possibly look like!! Thumbs Up My confidence has been writing cheques that my abilities can't cash for years.
Post #501522 7th Feb 2016 3:01am
YOLO110
Australia
Slight amendment... I did not actually use all of both packs of Dynamat! About 1.5 packs I think, so I do have enough left for the front... I hope!
And yes, the improvement is great... I don't have to turn the radio volume down when I slow down!
Cheers! YOLO... You Only Live Once...
Post #501534 7th Feb 2016 8:24am
Pickles
Pete, AWESOME job mate,........AWESOME.
I wish I had your skills.
Well done, Martin.
Post #501537 7th Feb 2016 9:23am
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
Excellent write up, Pete, and a beautiful job done. Bow down Thumbs Up 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MT´s,
Recaro CS´s, anorak, wellingtons
Post #501538 7th Feb 2016 9:25am
Ryderoo
England 2015 Defender 90 Puma 2.2 HT Santorini Black
Nice job, I had Chris @ CSK do mine.
Good write up with excellent pictures. Bow down
Just........
One........
Slight .......
Criticism.......
You have not matched the pattern on the dynamat Shocked
Excellent job mate, wish I had time and skills for this. Thumbs Up Cheers Simon
I can explain it to you, but I can't understand it for you
1990 110 TD5 county, my first Land Rover - gone
2012 Discovery 4 XS SDV6 - gone
2014 Discovery 4 XS SDV6 - gone
2015 Evoque SD4 dynamic - Wife’s - gone
2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone
2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24
2021 Defender S D250 Santorini Black 110 HT - gone March 24
2023 Evoque P300e SE wife’s current vehicle
Post #501551 7th Feb 2016 10:02am
redline
Switzerland
Very nicely done! I'm just in the middle of doing mine, and now know that its not as easy as it looks to do a tidy job...
Post #501554 7th Feb 2016 10:16am
YOLO110
Australia
Cheers for the comments guys! Very Happy
This is one of those jobs that gives you immense satisfaction, before, during and after! Thumbs Up YOLO... You Only Live Once...
Post #501571 7th Feb 2016 11:28am
p_jeeeee
Belgium 2007 Defender 90 Puma 2.4 SV 90 Caprice
is realy looking good!
Post #501584 7th Feb 2016 12:03pm
mk1collector
It also gives you loads of cuts on your fingers if you don't wear gloves Rolling with laughter Ray
My build thread
Post #501590 7th Feb 2016 12:08pm
Anderzander
And it really isn't difficult to do - I'd encourage anyone hesitating about whether they could do it - to do it Very Happy
Post #501609 7th Feb 2016 12:30pm
YOLO110
Australia
Agreed!
And not a spot of blood spilled... AND I take Warfarin too! Razz YOLO... You Only Live Once...
Post #501611 7th Feb 2016 12:32pm
L110CDL
Nice job done YOLO110 Thumbs Up
Post #501884 7th Feb 2016 10:08pm
Venomator
YOU DID IT... :)
Finally... Whistle
Well done job Pete, you should be very happy and proud of that mate... Bow down
And a bloody good write up with plenty of time for pics along the way too, awesome, as Martin has said, AWESOME... Mr. Green
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #501915 7th Feb 2016 11:14pm
Page 1 of 3 123>
