![]() | Home > Maintenance & Modifications > Rear Bumperettes for 110 |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
Just use a small washer and don`t worry about it
gav///m5 Member Since: 02 Oct 2010 Location: south staffs Posts: 6 ![]() ![]() |
I have a mantec rear wheel carrier on my 2005 xs 110
I have been given for christmas a pair of very sturdy bearmach rear bumperettes the n/s will fit quite easily however the o/s has the lower bracket for the wheel carrier in its way - is it a case of modifying the bumperette to fit around the bracket ? |
I had to modify my bumperette for my td5 110 because of the mantec spare wheel carrier, i removed the bumperette, then removed the chequer plate, shortened the square tube and chequer plate and re-attached, the bumperette is about 50mm shorter but all works fine.
PM me your email address and I can send a photo |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584 ![]() ![]() |
Like many add ons to Defenders they come in a wide range of style and quality.
Not all bumperettes are the same! Not all rear bumperettes fit with all rear wheel carriers. Many years ago I bought some rear bumperettes off ebay (YES I know ![]() ![]() Click image to enlarge Trouble is you take some of the strength out of them and stepping off rocks I can bend it upwards. These are galvanised and designed to fit with rear wheel carrier ![]() Click image to enlarge HTH Brendan Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
