Home > Maintenance & Modifications > Rear Bumperettes for 110
Page 3 of 3 <123
Trevor Wright
In the process of fitting a pair of RRC2970/71 (military) bumperettes to my '08 Puma 90 XS SW and have a query about best practice on bolting on the inside of the rear crossmember.
The inside of the rear crossmember is U section and where the M10 holes come through there is little room for a decent-sized washer as the holes are rather close to the edge wall of the U.
I suspect that the "proper" solution is a packing piece/block to fill the U and a plate on top to bridge the tops of the U. All a bit technical for me unless such things can be purchased.
But what do the rest of you do - just use a small washer and bolt straight to the back of the crossmember?
Thanks. Trevor Wright
'08 90 TDCi/TD4 XS SW
Post #13904 6th Aug 2009 7:10pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Just use a small washer and don`t worry about it Thumbs Up
Post #13907 6th Aug 2009 9:00pm
gav///m5
2005 Defender 110 Td5 XS CSW Cairns Blue
I have a mantec rear wheel carrier on my 2005 xs 110
I have been given for christmas a pair of very sturdy bearmach rear bumperettes
the n/s will fit quite easily
however
the o/s has the lower bracket for the wheel carrier in its way - is it a case of modifying the bumperette to fit around the bracket ?
Post #49889 27th Dec 2010 5:21pm
I had to modify my bumperette for my td5 110 because of the mantec spare wheel carrier, i removed the bumperette, then removed the chequer plate, shortened the square tube and chequer plate and re-attached, the bumperette is about 50mm shorter but all works fine.
PM me your email address and I can send a photo
Post #49948 28th Dec 2010 8:07am
leeds
Like many add ons to Defenders they come in a wide range of style and quality.
Not all bumperettes are the same!
Not all rear bumperettes fit with all rear wheel carriers.
Many years ago I bought some rear bumperettes off ebay (YES I know Razz ) Not galvanised and need modifying to fit rear wheel carrier like this
Trouble is you take some of the strength out of them and stepping off rocks I can bend it upwards.
These are galvanised and designed to fit with rear wheel carrier
HTH
Brendan
Post #49987 28th Dec 2010 2:58pm
Page 3 of 3 <123
