Home > Technical > [Electronic Engineer: Mode On] Advise for Dual Battery Sys
Page 2 of 3 <123>
randjafloat
United Kingdom 2016 Defender 110 Puma 2.2 XS CSW Montalcino Red
We have more AGM batteries than I care to think of (in case they all need replacing at the same time!) in marine use. Fully support the comments above about the benefits / drawbacks. Our setup is broadly as per the schematic Peter Td4 posted except we have 5 banks of AGMs and a pair of Victron inverter/chargers.
Most alternators can be tweaked to give a suitable voltage output but for longevity, AGM's like a proper phased charge which only a regulator / charger with a battery temperature probe can offer. Good chargers set up for AGM's also give an "equalising charge" (higher then normal voltage) occasionally to clean up the battery plates.
One thing to bear in mind - AGM's do not like being left partially discharged for long periods. They like to be brought back to 100% regularly.
However, if you do that their lifespan is amazing when you only pull them down to 60% or so on a regular basis. Their self discharge when standing is really low too. Overall, many benefits if you make sure that the charging regime treats them properly when up to 1,000 charge /discharge cycles are possible. We achieve that on boats and that would be a lot of camping trips! High upfront cost but great lifespan.....
Post #490425 9th Jan 2016 10:04pm
DEF_Jam
Italy 2008 Defender 90 Puma 2.4 SW Stornoway Grey
So I got the 2 Odissey and the split fuse box from Blue sea.
I'm not really understanding about the time and the consume.
When you say 2 days for the fridge you mean 2 days without moving the car right?
And if that's correct, how long you'll need to ride your car till you can stop for another 2 days?
About relay I can't really choose between the IBS (I'm waiting for an answer because I found online more models than the models on their website) and the Cyrix.
Any exprience or advise would be appreciate
Post #490501 10th Jan 2016 1:40am
ericvv
Worth a read I think...
The OEM Varta LFD90 does seem a dual purpose battery all right.
http://www.varta-automotive.com/en-gb/prod...30-090-080
And then these here below from an old thread, what I found to be the least biased educated battery advise ever written on here.
tatra805 wrote:
Original battery is a Varta Profesional Deep Cycle Marine Leisure , 90Ah/800CCA, code LFD90
Wont go into opinions, beaten to death already.
tatra805 wrote:
Ok, well, cant keep out of it anymore Whistle
Some battery ranting
Most terms are used mixed and regardless of real construction parameters.
AGM, GEL, Deep Cycle, capacity, etc etc
AGM - GEL �WET
Status of the electrolyte
AGM: inside a glassfibre matting,
GEL: Gel status, not liquid
WET: just the liquid electrolyte
Wet has the disadvantage it will leak when upside down as the electrolyte is a pure liquid. The �plates� are nothing more than lead plates. In the mean time no leaking till 90� for short time solved by matrixes in the battery caps and the plates evolved to matrixed plates for bigger contact surface etc etc
Gel solved the leaking issues, still venting is necessary but the gell is not passing through the sintered filter openings. (eg optima) The disadvantage of gel is that it does not transfer charges as easily,(the gelling part of the formulation is not conducting) hence the need for spiral designs, which just means there is a bigger contact surface between the plates and the electrolyte. This resulted also in a better CCA, as this is directly related.(bigger surface can conduct more energy at same time) But as less active electrolyte per cubic the capacity of the same external volume of the battery is lower. (simply put there is more lead vs electrolyte in it, less electrolyte = less capacity + less electrolyte as the gelling agents are also taking part of the place)
AGM is the �new hot topic� but nothing more than an in-between. Instead of making gell you absorb the normal liquid in a matting. Less chance on leaking + clever venting matrix designs makes them quasi as safe as a gel type. Liquid instead of gel makes for better contact and charge exchange so capacity is up (a bit) and in case combined with a spiral design of the lead plates an even higher CCA than GEL.
(exclude variants)
(note that leaking is also related to gassing when charging, sealed batteries need a better controlled and at lower amp charging process as gasses cannot escape and would make the batteries explode under pressure build up. Also Optima has venting holes, AGM batteries also to allow for a faster charging spec (but still slower than an open battery))
Due to the bigger contact areas (and with the right charging systems) you can �deep cycle� the AGM and Gel better than a simple plate design.
Sulfurisation of the plates is also less an issue as you have more plate surface available. (sulfur on plates= no more conducting, 5% of a classic plate or 5% of a 10 times bigger spiral surface makes the plate is quicker to not charging anymore while the spiral will. It is the charging process that kind of auto-cleans the plates but you need a min current for that which the plates are not able to conduct anymore in that case)
But still, even on optima and others, this is a far cry from real traction batteries which are real deep cycle.
Deep cycling means discharging till 40% of charge. ALL batteries can do this but not all can recover from it. A real traction battery can take up to 3000 deep cycles, a GEL/AGM/ WET deep cycle or leisure battery up to 300, a normal classic lead acid 0 if lucky you�ll survive a couple.
So,if you want top level deep cycling, as you know you will run your batteries empty each and every time and you will only have the chance to charge them x time after that, go for sealed traction batteries. They will cost you 6 times more but you can expect 20 years from them in those conditions. (well, yes 10 years if you flatten them completely 300 times per year� and that is manufacturer guarantee)
You�ll need to build up your banks with individual 6 or 12V cells till you reach your desired capacity.
Now why all this explanation?
There is no reason to prefer GEL or AGM IF you do not have a leaking/positioning issue.
With a wet deep cycle battery you will get:
- normal CCA
- almost double capacity Ah (90 vs 55)
- 1/3 rd of cost
- identical deep cycle resistance
So people into competition that must run under any angle I completely support in their choice of AGM/GEL.
But for campers, overlanding or home warriors I do see a disadvantage in them and although I consider them though and good batteries a waste of money in those situations.
A 50Ah Gel battery will not run your fridge and webasto for 12 hours, even if after recovery the battery has enough juice to restart the systems and run for another hour the build in voltage detectors of your fridge and webasto will switch off after about 6-8 hours.
(not taking in consideration extreme temps/other users which makes things only worse)
With a wet cell you will run them 10-12 hours as you simply have 45% more Ah available.
It was a positive surprise to me to see that Landrover itself selected a deepcycle battery as oem and not a classic car starter battery. (see my previous post)
Another point which I consider important for me.
When putting 2 OEM (or varta�s) of equal type parallel as normal and AUX battery you don�t need a special charging system. When putting a wet and eg an optima in parallel you will never charge them correctly and this will lead to premature failure of the weakest of the two.
So you�ll need to put in a split charging device. (that is not a 100� fancy battery separator as the national-luna etc, it is a separate charging system as found in marine applications or eg the CTEK one)
Or you�ll have to put in 2 optimas at once. Project cost immediately double and you�ll only have 2x50Ah instead of 2x90Ah. (both CCA enough for starting but the optimas will give in earlier, I guarantee, it's math)
I like equipment and the more the better but not if it is unnecessary.
To me all these batteries have their place and application. But I had too many friends asking me to help them out with constant empty optima�s blaming everything but not understanding that Ah was the only thing they needed in the first place and not the latest hype.
To make it a bit constructive and to answer the original question
1. Don�t deep cycle your batteries, it is an option only for extreme/emergency situations with anything but real traction batteries anyway.
2. Calculate you capacity needed, without that you�ll run out of juice with any type of battery
3. Consider your existing equipment, doesn�t make sense to make things worse.
4. Tune your equipment, right battery for right charging system etc
5. Count your coins as everything is possible and each approach has its pricetag
Respect above 5 and you�ll be a happy camper. Take a shortcut and you�ll put a weak link in the your system.
Friendly 2cents only Very Happy
PS: I have hands on experience with all types mentioned above except AGM�s. (But also studied their specs) in all different types of applications (stationary and mobile)
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #490514 10th Jan 2016 8:09am
Peter Td4
Belgium 2008 Defender 110 Puma 2.4 HCPU Santorini Black
Eric,
Thanks for digging up this very useful contribution.
It really says a lot !
Again, what is not mentioned is the ability of AGM to quickly absorb a charge; which is a question indirectly raised by the DEF_Jam as he wants to know how long he'll need to be driving before he can go to his next camping site.
In mobile (rover) applications, this is an important consideration.
This goes hand in hand with my advise NOT to use the chassis as a negative return. Resistance losses are not properly controlled and they do have a huge negative impact on the bulk charging current.
Just as well, use cables with sufficient diameter.
To come to a good working mobile energy system is not difficult, but you have to follow a number of good practices Wink Peter,
Defender 110 StaWa - Td5
Defender 110 HCPU - Puma
Defender 90 Soft Top - Td5
Post #490563 10th Jan 2016 1:01pm
leeds
Maybe it is time to step back and go back to basic before getting tied up in technical specifications of different batteries.
Battery technology, recharging technology, cooling technology, navigation and ICE technology is all changing at a rapid pace. What was right/best 10/5/2/1 years ago might not be the best today.
1) NEEDS. What do you need your Defender to do? Commute to work, or cross deepest darkest Africa? Take part in the hardest winch challenge or just potter down the occasional green lane?
2) WANTS. You may want sky blue pink, leather upholstery with hearts and your initials emblazed on them, but does it actually assist in your daily commute to work? You may want the biggest bogoff winch available but is it needed for the daily commute?
3) BUDGET. People personal disposable income varies tremendously, so decide on your total budget available or what you can afford each month.
4) EDUCATION. Try to understand what different specification means, that way you can make a more informed decision about your actual needs. For instance a smaller capacity battery (AHr) with a bigger DOD (depth of discharge) has more useful capacity then a larger AHr battery with a lower DOD. A fridge with a higher average current draw will discharge a battery faster then one with a lower average current draw.
The main principal use of a car battery is TO START THE ENGINE. OK it might be irritating if you can not start your vehicle in leafy Surrey. It could mean DEATH if you can not start your engine in the middle of the Simpson Desert.
Decide what you intend to do with the Defender then plan your needs accordingly. If you are planning on a 2 week trip to Morocco in a group, moving on every day then twin batteries might not be necessary as if need be you can get a jump start off another vehicle. A solar panel might be useful to trickle charge your batteries. Planning on a trip to Nordkapp in midwinter a solar panel will not be much use.
Number 1 priority is starting your engine.
Work out the current draw of all the appliances you will be using. This will give you some idea on how long your batteries will last.. Consider appliances with a battery monitor built in which will disconnect the appliance at certain voltages. A fridge with a current draw of less then 1 amp may be a better bet then a fridge with a current draw of 3 amps costing a lot less if you are stopping for long periods.
Consider a battery alarm system which will tell you when the battery voltage has dropped to a certain voltage. Some of the split charge system have this as a feature.
So consider your needs carefully, do your own research and plan your vehicle to fulfill your needs/dreams.
Must admit I will follow up any suggestions on here as I have a blank canvas vehicle to decide what to do with and I have not got around to thinking about the battery/electrical side of things yet. So yes I have an interest in how this thread develops.
Brendan
Post #490580 10th Jan 2016 1:46pm
DEF_Jam
Who tells me the differeces between these two and which one looks better:
-https://www.victronenergy.it/battery-isola...-combiners
-http://ibs-tech.ch/en/products/dual-batter...relay.html
Post #490831 11th Jan 2016 12:51am
Peter Td4
According to me they are just the same product.
Only some of the IBS models have LED indicators. Peter,
Post #490832 11th Jan 2016 12:58am
DEF_Jam
Should I place an on/off switch right before the 12v sockets or it's not necessary?
Post #491380 12th Jan 2016 12:50pm
Cupboard
Depends if you want to switch stuff off and leave it plugged in.
If the 12V socket is somewhere nasty then there can be some corrosion related benefits to turning it off too.
Post #491397 12th Jan 2016 2:17pm
PRENT1
United Kingdom 2011 Defender 110 Puma 2.2 XS CSW Santorini Black
Auto electrician Bromley area
Anyone know or have used an auto electrician in the Bromley area they would recommend. I have a couple of bits i would like added with a little bit of TLC.
Post #491412 12th Jan 2016 3:16pm
redline
Switzerland
Some excellent posts on this thread! The knowledge generously shared by posters is very valuable, particularly for newbie Defender owners such as myself Smile
I don't want to get into the great battery debate, but just point out that I have used Optima batteries for the last 15yrs across road cars, rally cars, boats, 4x4's and an overlander (just not a Defender). So far they have never let me down, despite the tough climactic conditions they operated in.
Are they as good as the Odyssys? Who knows.... maybe not...
Are they good enough for what you are doing? No doubt about it....
Post #491896 13th Jan 2016 7:24pm
redline
Switzerland
I just finished a very similar installation on my 110, using the following:
- Blue Sea 12way fusebox
- Blue Sea 7622 split charge relay
I purchased the split charge system pre-wired inc. switch from Mobile Centre (one of the site sponsors).
There are probably better items available, but having used both the Blue Sea fusebox and relay previously on boats, I was very comfortable with these.
Btw - I initially wanted to install the Adnersen connector in a GMB locker in the fender, but eventually settled on fixing it to the front of the battery box in order to keep the cabling run short.
Post #491910 13th Jan 2016 7:51pm
DEF_Jam
So I went for a IBS-DBR which is the relay only but after being in contact with Beat from IBS I learned this from his words:
"Both systems have the same architecture and offer the same performance. DBR is made for installations where not feedback to the user is needed. IBS-DBS is made for those who travel and want to know what happens to the batteries. IBS-DBS has as addition the 2 hours link what is used for electric recovery winches, DBR only offers a 30min link."
Do you think I can connect a gauge like this one to keep an eye on the batteries?
Another question is about the CTEK charger. Do I have to connect it to the AUX battery only right?
How it would work when I'm stop camping and the charger will be plug into the 220v tower and with the two Odyssey connected with the IBS relay?
I've also thought about the possibilty of create 220v with an inverter and looking at camper/rv forums I've found this as a good option:
http://www.marc-ting.com/shop/product_info...html&=
I know it could be an excuse to bring some useless devices on your trip but I'll be careful and since I'm traveling with my girlfriend I can't tell her there will be no hair dryer in the bush
Post #494616 21st Jan 2016 1:46am
Cupboard
You might be better off telling her there's no hair drier!
A hair drier at 1.5-2kW would take up all the alternator's output (its 150A on a Puma, so about 2kW at peak output, not taking it to account other loads and inefficiencies) and very quickly drain a battery.
Where possible, and it isn't always, you're better getting 12V appliances. They work much more efficiently. A lot of things need low (ish) voltage DC, and changing from 12VDC, to 230VAC, to DC again is far more wasteful than a straight DC-DC conversion.
Edit: on the voltmeter. That would be one good solution. They all take a small amount of current though, how much and whether that's significant in terms of your battery capacity would depend on the meter. No reason you couldn't have a momentary button to push when you wanted to see the voltage.
Post #494639 21st Jan 2016 8:49am
DEF_Jam
I took a look around and I will tell her there is no hair dryer Mr. Green
Wind and sun will do the job.
About the CTEK charger and the 2 batteries linked with the IBS relay I can answer, again, with Beat's words from IBS:
"Just add the Charger to AUX battery, while charging and exceeding 13.3V on Aux Battery also Main battery will be linked in charged together. If main battery is quite low and/or charger performance is less than 10Amp the DBR might cycle a few times until staying permanently linked. First Main as to be brought to some charge until DBR can saty linked (this is just following physical laws)."
I like the idea to have a momentary switch to push for a battery check.
Two batteries means two voltmeters but can I link them to the same momentary switch?
Post #494689 21st Jan 2016 11:41am
Page 2 of 3 <123>
