![]() | Home > Technical > [Electronic Engineer: Mode On] Advise for Dual Battery Sys |
| DEF_Jam Member Since: 17 Jul 2011 Location: Milan Posts: 60
So I got the 2 Odissey and the split fuse box from Blue sea.
I'm not really understanding about the time and the consume. When you say 2 days for the fridge you mean 2 days without moving the car right? And if that's correct, how long you'll need to ride your car till you can stop for another 2 days? About relay I can't really choose between the IBS (I'm waiting for an answer because I found online more models than the models on their website) and the Cyrix. Any exprience or advise would be appreciate |
| ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817
Worth a read I think...
The OEM Varta LFD90 does seem a dual purpose battery all right. http://www.varta-automotive.com/en-gb/prod...30-090-080 And then these here below from an old thread, what I found to be the least biased educated battery advise ever written on here.
You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw Last edited by ericvv on 10th Jan 2016 1:36pm. Edited 1 time in total |
| Peter Td4 Member Since: 23 Oct 2010 Location: Antwerp, Belgium Posts: 228
Eric,
Thanks for digging up this very useful contribution. It really says a lot ! Again, what is not mentioned is the ability of AGM to quickly absorb a charge; which is a question indirectly raised by the DEF_Jam as he wants to know how long he'll need to be driving before he can go to his next camping site. In mobile (rover) applications, this is an important consideration. This goes hand in hand with my advise NOT to use the chassis as a negative return. Resistance losses are not properly controlled and they do have a huge negative impact on the bulk charging current. Just as well, use cables with sufficient diameter. To come to a good working mobile energy system is not difficult, but you have to follow a number of good practices Defender 110 StaWa - Td5 Defender 110 HCPU - Puma Defender 90 Soft Top - Td5 |
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584
Maybe it is time to step back and go back to basic before getting tied up in technical specifications of different batteries.
Battery technology, recharging technology, cooling technology, navigation and ICE technology is all changing at a rapid pace. What was right/best 10/5/2/1 years ago might not be the best today. 1) NEEDS. What do you need your Defender to do? Commute to work, or cross deepest darkest Africa? Take part in the hardest winch challenge or just potter down the occasional green lane? 2) WANTS. You may want sky blue pink, leather upholstery with hearts and your initials emblazed on them, but does it actually assist in your daily commute to work? You may want the biggest bogoff winch available but is it needed for the daily commute? 3) BUDGET. People personal disposable income varies tremendously, so decide on your total budget available or what you can afford each month. 4) EDUCATION. Try to understand what different specification means, that way you can make a more informed decision about your actual needs. For instance a smaller capacity battery (AHr) with a bigger DOD (depth of discharge) has more useful capacity then a larger AHr battery with a lower DOD. A fridge with a higher average current draw will discharge a battery faster then one with a lower average current draw. The main principal use of a car battery is TO START THE ENGINE. OK it might be irritating if you can not start your vehicle in leafy Surrey. It could mean DEATH if you can not start your engine in the middle of the Simpson Desert. Decide what you intend to do with the Defender then plan your needs accordingly. If you are planning on a 2 week trip to Morocco in a group, moving on every day then twin batteries might not be necessary as if need be you can get a jump start off another vehicle. A solar panel might be useful to trickle charge your batteries. Planning on a trip to Nordkapp in midwinter a solar panel will not be much use. Number 1 priority is starting your engine. Work out the current draw of all the appliances you will be using. This will give you some idea on how long your batteries will last.. Consider appliances with a battery monitor built in which will disconnect the appliance at certain voltages. A fridge with a current draw of less then 1 amp may be a better bet then a fridge with a current draw of 3 amps costing a lot less if you are stopping for long periods. Consider a battery alarm system which will tell you when the battery voltage has dropped to a certain voltage. Some of the split charge system have this as a feature. So consider your needs carefully, do your own research and plan your vehicle to fulfill your needs/dreams. Must admit I will follow up any suggestions on here as I have a blank canvas vehicle to decide what to do with and I have not got around to thinking about the battery/electrical side of things yet. So yes I have an interest in how this thread develops. Brendan |
Who tells me the differeces between these two and which one looks better:
-https://www.victronenergy.it/battery-isola...-combiners -http://ibs-tech.ch/en/products/dual-batter...relay.html |
According to me they are just the same product.
Only some of the IBS models have LED indicators. Peter, Defender 110 StaWa - Td5 Defender 110 HCPU - Puma Defender 90 Soft Top - Td5 |
Should I place an on/off switch right before the 12v sockets or it's not necessary?
| Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971
Depends if you want to switch stuff off and leave it plugged in.
If the 12V socket is somewhere nasty then there can be some corrosion related benefits to turning it off too. |
| PRENT1 Member Since: 02 Sep 2015 Location: bromley Posts: 43
Anyone know or have used an auto electrician in the Bromley area they would recommend. I have a couple of bits i would like added with a little bit of TLC.
| redline Member Since: 28 Jun 2015 Location: Mountains and Lakes Posts: 221
Some excellent posts on this thread! The knowledge generously shared by posters is very valuable, particularly for newbie Defender owners such as myself
I don't want to get into the great battery debate, but just point out that I have used Optima batteries for the last 15yrs across road cars, rally cars, boats, 4x4's and an overlander (just not a Defender). So far they have never let me down, despite the tough climactic conditions they operated in. Are they as good as the Odyssys? Who knows.... maybe not... Are they good enough for what you are doing? No doubt about it.... Last edited by redline on 13th Jan 2016 7:54pm. Edited 2 times in total |
I just finished a very similar installation on my 110, using the following:
- Blue Sea 12way fusebox - Blue Sea 7622 split charge relay I purchased the split charge system pre-wired inc. switch from Mobile Centre (one of the site sponsors). There are probably better items available, but having used both the Blue Sea fusebox and relay previously on boats, I was very comfortable with these. Btw - I initially wanted to install the Adnersen connector in a GMB locker in the fender, but eventually settled on fixing it to the front of the battery box in order to keep the cabling run short. |
So I went for a IBS-DBR which is the relay only but after being in contact with Beat from IBS I learned this from his words:
"Both systems have the same architecture and offer the same performance. DBR is made for installations where not feedback to the user is needed. IBS-DBS is made for those who travel and want to know what happens to the batteries. IBS-DBS has as addition the 2 hours link what is used for electric recovery winches, DBR only offers a 30min link." Do you think I can connect a gauge like this one to keep an eye on the batteries?
Another question is about the CTEK charger. Do I have to connect it to the AUX battery only right? How it would work when I'm stop camping and the charger will be plug into the 220v tower and with the two Odyssey connected with the IBS relay? I've also thought about the possibilty of create 220v with an inverter and looking at camper/rv forums I've found this as a good option: http://www.marc-ting.com/shop/product_info...html&= I know it could be an excuse to bring some useless devices on your trip but I'll be careful and since I'm traveling with my girlfriend I can't tell her there will be no hair dryer in the bush |
You might be better off telling her there's no hair drier!
A hair drier at 1.5-2kW would take up all the alternator's output (its 150A on a Puma, so about 2kW at peak output, not taking it to account other loads and inefficiencies) and very quickly drain a battery. Where possible, and it isn't always, you're better getting 12V appliances. They work much more efficiently. A lot of things need low (ish) voltage DC, and changing from 12VDC, to 230VAC, to DC again is far more wasteful than a straight DC-DC conversion. Edit: on the voltmeter. That would be one good solution. They all take a small amount of current though, how much and whether that's significant in terms of your battery capacity would depend on the meter. No reason you couldn't have a momentary button to push when you wanted to see the voltage. |
I took a look around and I will tell her there is no hair dryer
Wind and sun will do the job. About the CTEK charger and the 2 batteries linked with the IBS relay I can answer, again, with Beat's words from IBS: "Just add the Charger to AUX battery, while charging and exceeding 13.3V on Aux Battery also Main battery will be linked in charged together. If main battery is quite low and/or charger performance is less than 10Amp the DBR might cycle a few times until staying permanently linked. First Main as to be brought to some charge until DBR can saty linked (this is just following physical laws)." I like the idea to have a momentary switch to push for a battery check. Two batteries means two voltmeters but can I link them to the same momentary switch? |
