Home > Technical > [Electronic Engineer: Mode On] Advise for Dual Battery Sys
Page 3 of 3 <123
Cupboard
Yes, you just need a double pole switch.
You don't actually need two voltmeters, a single pole, double throw switch would mean you could use the same voltmeter for both batteries.
Option 1: one switch, two meters. One battery in to one side of the switch, voltmeter out the same side. Other battery in to the second side, voltmeter out the second side.
Option 2: one switch, one meter. Bear in mind you need a three way switch for this instead of a two way, so you have centre off. Battery 1 in to one side, voltmeter out of the middle, battery 2 in to the other side. I've just used a couple of these switches: http://cpc.farnell.com/unbranded/abrr003/s...dp/SW02926 for a similar purpose - my rear work light is either off, on or controlled from the front, same as a socket I've got next to it.
Make sure you fuse the the cables from the batteries to the switch/meters. It may not be taking any current but it can still go wrong Thumbs Up
Post #494778 21st Jan 2016 2:16pm
DEF_Jam
Italy 2008 Defender 90 Puma 2.4 SW Stornoway Grey
So guys, I collected a part of the shopping list for the dual battery system and now I'm bringing this back because it's the wiring time and I need to get all the connectors, wires, battery and cables terminals.
This is what I ended up drawing:
I'm going to use a 50mm2 from here http://www.ebay.it/itm/281217301497 to connect the batteries to the IBS relay and the two andersons.
My questions are now about the cable sizes and connectors to use for the wiring.
I would like the rear left worklamp to switch on when I insert the reverse gear and the two of them to switch on when I use the fron panel switch.
I would need a solution like this one found on this forum for the connector that will bring the power to the 4 front lights and a 12V socket mounted on the roof rack that I will keep close when the roof rack it's not on.
They come from here http://www.bulgin.com/products/circular-po...ndard.html but I don't know which one to get for my setup on the roof rack.
I'm going to place an order at mobilecentre website because I need the tray for the two Odyssey and I also know they read this forum so if by any chance they are reading this I would like to discuss what do I need out of their kit since I've already something with me.
https://www.mobilecentre.co.uk/index.php?m...cts_id=909
Post #499703 2nd Feb 2016 10:23pm
leeds
Question, why 2 off 50 amp Anderson connectors?
A single 175 amp Anderson connector would be more suitable in my opinion
For an emergency start you are better off with a 175 amp Anderson connector
Your compressor is 45 amp, you have a couple of choices put an inline 45 amp fuse close to the compressor and a 175 amp connector on the end of the wiring. This would mean soldering the wires into the 175 contacts and then ideally some strain relief on the contacts via some insulation tape and a loop of cable.
The alternative is a 175 amp connector then a short length of say 10mm2 cable to a 50 amp Anderson connector.
Brendan
Post #499739 2nd Feb 2016 11:31pm
DEF_Jam
You are correct. I would just say the two anderson connectors (edited and corrected on the post).
One will be placed under the wing and connected to the starter battery only for emergency.
Any idea where to pass?
The other one I'm thinking of a sort of panel with two 12v sockets (water pump and fridge) and switch (for the "switch services") behind the cubby box also because I feel like I'm going to use the under cubby box safe I have to place the fusebox and the battery charger.
Post #499747 2nd Feb 2016 11:49pm
redline
Switzerland
DefJam: I suggest that give mobile centre a call. They are very helpful, and "modified" their kit to suit my own particular requirements.
Post #499786 3rd Feb 2016 6:10am
Peter Td4
Belgium 2008 Defender 110 Puma 2.4 HCPU Santorini Black
Fuses definitely have to go on the positive wires, not the negative Exclamation Peter,
Defender 110 StaWa - Td5
Defender 110 HCPU - Puma
Defender 90 Soft Top - Td5
Post #499806 3rd Feb 2016 9:53am
DEF_Jam
Sure Peter Thumbs Up
I ended up learning that it's quite impossible to use an Anderson connector with the cables I have.
They are special very flexible 50mm2 cable for welding but they are about 13,5mm diameter.
http://www.ebay.it/itm/Cavo-saldatura-EXTR...1603679402
So I'm going to use the proper connectors from the same italian factory.
http://www.ebay.it/itm/Presa-fissa-femmina...SwxH1T~0cd
http://www.ebay.it/itm/Connettore-rapido-m...Swl9BWKjm9
My big doubt it's about the back socket/plug to bring power to the roof rack.
If I'm correct I'm going to have 10 wires out from the fuse box (2 wires from each front light x4=8 + 2 wires for the roof rack 12v socket to have power inside the tent) and they are going to be running from the under cubby box space to the top rear corner of the car (as the picture I posted with the work lamp) where they are going to meet a connector.
I will keep that sealed when the roof rack it's not on and plug in the connector with the cable coming from the roof rack when it's on.
Is this too long for those wires?
How big the cable should be in relation to how many Ampere I should consider to have for the 12v socket up there?
Post #499960 3rd Feb 2016 4:47pm
Peter Td4
I would definitely not use welding connectors.
These welding connectors have one side that is exposed and that is far too dangerous for making a short circuit.
This is the beauty of the Anderson connector; it is really designed for high-current DC applications.
So please be careful !
On the wire size, there are plenty of calculators.
Please be aware that on a low voltage DC system you have to pay much more attention to voltage drop than on a domestic 230V installation.
A 12V DC system is more critical in that sense.
Take a look at this one:
https://www.bluesea.com/resources/1437
It still uses feet as measure of length Laughing , but that's easy to convert. Peter,
Post #499968 3rd Feb 2016 5:02pm
DEF_Jam
Peter as you can see there is someone else that did this job and he's very pleased with that.
The only difference is that I'm going to have 2 of them on a panel behind the cubby box and two under the wing with a sealed mini panel as well.
It's in consideration of voltage drop that I'm going for 50mm2 cables.
Post #499970 3rd Feb 2016 5:14pm
Cupboard
Whilst I'd agree that Anderson are the nicest way to do it, if you want to see slightly alarming design you should see the jump start posts on some tractors. It's just two post sticking out behind a plastic flap.
Post #499989 3rd Feb 2016 6:01pm
DEF_Jam
About the switch I have to use for the "switch" part of the fuse box do I have to calculate the full Ampere amount of the seriveces connected and go for a 50A switch?
Post #500334 4th Feb 2016 12:48pm
Peter Td4
Def_Jam, it is all about safety.
Technically seen these welding connectors are certainly adequate, but with the exposed metal you can generate quite nice fireworks if you unintentionally touch a metal body part whilst you have a battery connected to the other side of the cable.
Anyway, in case of jump starting, if you follow the golden rule to first connect the Plus sides on both vehicles, and only then the Minus sides, you will eliminate the biggest risks.
For the switch you would rather want to use an oversized model. The key in low-voltage high-current installations is to keep the total resistance down, just to make it bulletproof and reliable. Peter,
Post #501565 7th Feb 2016 10:57am
DEF_Jam
Thanks Peter, I did change my mind on pulling such a big cable under the wing only for jump start.
I was doing it just because I meant to have them ready if I'm going to add a winch.
I'm just going to pull a sealed anderson for now.
About the switch, since the oversized ones are pretty ugly, what about to use a realy associate to the switch?
Post #502198 8th Feb 2016 5:30pm
Peter Td4
You could use a relay for the purpose, but keep in mind this will have constant power consumption.
In stand-by use, meaning when the car is not being used frequently, you don't want to have this.
Would a recessed switch not be a solution ?
FCX, a site sponsor, is selling this and it really is good stuff. Matt showed it to me when I visited his place some time again and it would be my first choice if I needed a battery switch. Peter,
Post #502217 8th Feb 2016 6:18pm
DEF_Jam
I'm not sure I'm looking for a battery switch because it's going to be a fuse box switch.
It will turn on the sevices or sockets passing throught a dedicated space on the fuse box.
I was thinking to keep that space in the fuse box for what concern the roofrack services (which they will be 4 spotlights and a socket for the tent not always mounted on the car) and the other two "camping" devices socket fridge and water pump.
Post #502223 8th Feb 2016 6:35pm
Page 3 of 3 <123
