![]() | Home > Maintenance & Modifications > Mod-free snorkels |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
Yep dental floss took mine off, then a lot of thumb rubbing to get the residue off
As an aside:
As I mentioned in another thread on the subject a while ago, Sikaflex [bearing in mind there's more than one spec] is good stuff. That said if you are sticking something directly onto a painted surface then the adhesion will only be as good as the bond of the paint / primer to whatever is underneath - in this case the windscreen frame itself. As most rigid RAI / snorkel's are held fairly firmly at the intake the top frame bracket does not have to do a lot of load bearing work. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20912 ![]() ![]() |
MOG - Very true, I did read that post.
And yes, correct Sikaflex is vital. One of the reasons why I've looked all of this up especially. |
TDCi Guy Member Since: 17 Aug 2014 Location: Yorkshire Posts: 286 ![]() ![]() ![]() |
I've bought the mantec one you posted with view to doing the same thing as well as making a more watertight seal to my 102mm intake pipe with a knocked up flange. I was thinking either sikaflexing the windscreen bracket or making up a second bracket which bolts to the ex-windscreen hinge.
However the snorkel I got from paddocks has come without a windscreen bracket at all it has put the job on hold slightly!! ![]() @tditomprice 100” Defender Hybrid 2010 Alaska White 90 HT |
