Home > Maintenance & Modifications > LRI carpets and stainless tread plates
Page 2 of 5 <12345>
leeds
I do not think have a photo to hand, however Steve shows them well. Thanks Steve Thumbs Up
No extra drilling is necessary.
However a bit of care is necessary when tightening the bolts down especially if there is carpet or sound proofing under the stainless strip. Tighten them down evenly and ensure you do not get a dip around any bolts by overtightening any bolts.
Brendan
Post #485944 27th Dec 2015 8:47pm
That was why I didn't tighten them too much, though I would so far for a while then just a little tighter a bit later.
EDIT****
Just found a better photo showing the whole thing.
I knew it'd pay to take photo's at the time to put here one day. Laughing
Post #485952 27th Dec 2015 9:07pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
custom90steve wrote:
Here's a photo fitted:
Steve, where did you get the corner strip from? Need something to cover up the tear in the corner of the matting on mine 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #485974 27th Dec 2015 9:50pm
Pickles
Very good they are too, mine need just a little more tightening as it's a tight fit to the door rubber at the bottom so tends to make the door bounce a little on the latch instead of closing. So you need to shut it a bit harder.
That's because I've got rubber and Dynamat under there though..
I see corner protectors there, but they don't appear to be screwed on?.....If so, how are they attached?
Pickles.
Post #485980 27th Dec 2015 9:55pm
Cheshire110
I'm guessing that photo was taken during fitting?? Cheers, David
Post #485981 27th Dec 2015 9:56pm
Rosco - YRM available here: http://www.yrm-metal-solutions.co.uk/Land-...-Protector
Pickles - David is correct, I just placed it there for a photo. It is indeed screwed on.
Post #485986 27th Dec 2015 10:04pm
Rosco
Cheers. I'll add to the to do list Thumbs Up 2007 - Stornoway Grey 90 XS SW - Gone
Post #485994 27th Dec 2015 10:23pm
chasthechippie
Just out of interest Land Rover stopped fitting carpets to the Utility around 2012 MY. I had a 2011 fitted with carpets and when I picked up my 2013 model was horrified to find none, took it back to be informed that they weren't even an optional extra, only now fitted to Station wagons so bought a set from Exmoor very good.
Post #485998 27th Dec 2015 10:28pm
YOLO110
Australia
So does anyone have the LRI carpets fitted please?
I am wanting to carpet my 90 over my newly installed dynamat... but now I just don't know which way to go... Exclamation
LRI
Exmoor
FCX
Question Question Question Question
Any feedback please? YOLO... You Only Live Once...
Post #486036 27th Dec 2015 11:22pm
Cheshire110
No but I'd appreciate similar feedback too 👍 Cheers, David
Post #486046 27th Dec 2015 11:40pm
nitram17
As always, thanks for the useful and helpful pointers Steve. Very Happy
Like you, I would prefer the less blingy and less easily scratched product. Sheep
Looks like I shall be contacting Brendan when I get my January pocket money (December's money is already spent!). Crying or Very sad
(Sorry Brendan, I missed the items when looking at your website - maybe I should use my pocket money for new glasses!).
My rear threshold (from SP who are up this way) is 'brushed' and gets lots of traffic. It looks fine and will certainly not end up like its predecessor.......
I have the paste and the ACF50 at the ready! Thumbs Up
All the best for the New Year.
Will
The YRM ones (front door)dont have a channel cut into them(its hard to tell from the picture) ..will any water that is collected in that channel flow towards the back of the door?
Post #486213 28th Dec 2015 2:24pm
Arsath
United Arab Emirates 2010 Defender 110 Puma 2.4 CSW Fuji White
Hi David,
I would suggest that you go with the LRI tread plates.. I installed them on my one.. the difference between the ones Steve has installed and the LRI tread plates are the bolts and the glossy finish, LRI ones come with nice round headed bolts with square head bottoms (for lack of words) see the image below. They give a nicer finish overall, the only pain is you have to tighten the nuts from underneath the car not sure if there is a better way to say this Rolling with laughter.. . I am totally satisfied with my purchase. It is cheaper to buy directly from the LRI website.
Post #486223 28th Dec 2015 2:40pm
I did notice those above, quite nice.
On both you need to tighten from underneath anyway at least I did to avoid and damage around the bolts up top.
Very easy job if you have no side steps but a little more awkward if you do.
Having said that it's a useful tool stand.
Make sure you don't change on gravel or grass too in case you lose a washer as it'll be a devil to find if you can at all!
Post #486241 28th Dec 2015 4:21pm
leeds
Arsath, that type of bolt is called a coach bolt. If it has a screw driver slot in the top it becomes a roofing bolt.
Looking at that photo to me it looks like a galvanised mild steel coach bolt rather then a stainless coach bolt. However it can be difficult to tell from a photograph. The stainless coach bolts we have are thinner in the rim, smoother finish and have rings on the head (IIRC)
When fitting any after aftermarket kit whilst parked on gravel/grass it is a good idea to put a tarp on the ground first. Can make finding that dropped nut, washer, socket much easier.
Brendan
Post #486316 28th Dec 2015 7:51pm
glpinxit
I'm interested in the answer to the 'carpet question' too. But after Dynamat (or similar) I will use mass-loaded vinyl - eg eBay eBay Item No. 151560151880 under the carpet. (At the risk of thread diversion, Dynamat type stuff is meant to damp panel resonance, MLV will reduce noise intrusion and carpet will muffle the interior so they each have a role.) Cheers, Guy.
Post #486319 28th Dec 2015 7:57pm
Page 2 of 5 <12345>
