Home > Maintenance & Modifications > LRI carpets and stainless tread plates |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19654 |
That was why I didn't tighten them too much, though I would so far for a while then just a little tighter a bit later.
EDIT**** Just found a better photo showing the whole thing. Click image to enlarge I knew it'd pay to take photo's at the time to put here one day. |
27th Dec 2015 9:07pm |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1813 |
Steve, where did you get the corner strip from? Need something to cover up the tear in the corner of the matting on mine 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
27th Dec 2015 9:50pm |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3755 |
I see corner protectors there, but they don't appear to be screwed on?.....If so, how are they attached? Pickles. |
27th Dec 2015 9:55pm |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2725 |
I'm guessing that photo was taken during fitting?? Cheers, David
Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
27th Dec 2015 9:56pm |
Rosco - YRM available here: http://www.yrm-metal-solutions.co.uk/Land-...-Protector
Pickles - David is correct, I just placed it there for a photo. It is indeed screwed on. |
27th Dec 2015 10:04pm |
Cheers. I'll add to the to do list 2007 - Stornoway Grey 90 XS SW - Gone
27th Dec 2015 10:23pm |
chasthechippie Member Since: 15 Aug 2014 Location: Cheshire Posts: 55 |
Just out of interest Land Rover stopped fitting carpets to the Utility around 2012 MY. I had a 2011 fitted with carpets and when I picked up my 2013 model was horrified to find none, took it back to be informed that they weren't even an optional extra, only now fitted to Station wagons so bought a set from Exmoor very good.
27th Dec 2015 10:28pm |
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1633 |
So does anyone have the LRI carpets fitted please?
I am wanting to carpet my 90 over my newly installed dynamat... but now I just don't know which way to go... LRI Exmoor FCX Any feedback please? YOLO... You Only Live Once... |
27th Dec 2015 11:22pm |
No but I'd appreciate similar feedback too 👍 Cheers, David
27th Dec 2015 11:40pm |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2260 |
The YRM ones (front door)dont have a channel cut into them(its hard to tell from the picture) ..will any water that is collected in that channel flow towards the back of the door? |
28th Dec 2015 2:24pm |
Arsath Member Since: 20 May 2015 Location: Sri Lanka Posts: 133 |
Hi David,
I would suggest that you go with the LRI tread plates.. I installed them on my one.. the difference between the ones Steve has installed and the LRI tread plates are the bolts and the glossy finish, LRI ones come with nice round headed bolts with square head bottoms (for lack of words) see the image below. They give a nicer finish overall, the only pain is you have to tighten the nuts from underneath the car not sure if there is a better way to say this .. . I am totally satisfied with my purchase. It is cheaper to buy directly from the LRI website. |
28th Dec 2015 2:40pm |
I did notice those above, quite nice.
On both you need to tighten from underneath anyway at least I did to avoid and damage around the bolts up top. Very easy job if you have no side steps but a little more awkward if you do. Having said that it's a useful tool stand. Make sure you don't change on gravel or grass too in case you lose a washer as it'll be a devil to find if you can at all! |
28th Dec 2015 4:21pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
Arsath, that type of bolt is called a coach bolt. If it has a screw driver slot in the top it becomes a roofing bolt.
Looking at that photo to me it looks like a galvanised mild steel coach bolt rather then a stainless coach bolt. However it can be difficult to tell from a photograph. The stainless coach bolts we have are thinner in the rim, smoother finish and have rings on the head (IIRC) When fitting any after aftermarket kit whilst parked on gravel/grass it is a good idea to put a tarp on the ground first. Can make finding that dropped nut, washer, socket much easier. Brendan |
28th Dec 2015 7:51pm |
glpinxit Member Since: 31 Jul 2010 Location: rural Somerset Posts: 152 |
I'm interested in the answer to the 'carpet question' too. But after Dynamat (or similar) I will use mass-loaded vinyl - eg eBay eBay Item No. 151560151880 under the carpet. (At the risk of thread diversion, Dynamat type stuff is meant to damp panel resonance, MLV will reduce noise intrusion and carpet will muffle the interior so they each have a role.) Cheers, Guy. |
28th Dec 2015 7:57pm |
