![]() | Home > Puma (Tdci) > Puma 2.4 engine oil leak |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1855 ![]() ![]() ![]() |
Vacuum pump!
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2063 ![]() ![]() |
Yep...vacuum pump!
Rogeo1983 Member Since: 19 Nov 2015 Location: Horsham Posts: 30 ![]() ![]() |
Ok guys,
Sounds like vacuum pump then! Is it hard to replace? Is there any diagrams online to show what to look at? Cheers |
I have just looked up the vacuum pump, and yes that looks like the source.
With the oil leak, where would the leak be from? Is it the gasket, or from the bearing. Thanks guys, really appreciate the quick replies |
Treebeard Member Since: 27 Jun 2012 Location: Forest of Dean Posts: 40 ![]() ![]() ![]() |
They cost about �100 and are simple to fit. latest pn was LR012183 when we did ours a couple of years back
This post might help:
http://www.defender2.net/forum/post44746.html |
Sorry pn was LR 014973
Plus gasket LR 004381. All covered on page 191 of the defender tdci workshop manual which you can find as a pdf on www
Thanks treebeard
I am guessing that your link www was reference to the lack of workshop manuals!!! I will pick one up tm and I think I will do a full service while I am getting dirty anyway! With the fact that this pump sprayed out oil under high pressure, is there anything else that I should be looking at while replacing the pump? Does the vacuum pump have its own engine oil supply? I don't quite understand how it works, or even why the engine oil is there under such high pressure. Many thanks |
Quite the opposite - look at the link to the other thread:
but then it's even easier - this will get you there: https://onedrive.live.com/?id=4BC2D89C85C7...9C85C7C171 |
