Home > Puma (Tdci) > Puma 2.4 engine oil leak
Rogeo1983
2010 Defender 90 Puma 2.4 CSW Zambezi Silver
Hi Folks,
Today while driving the oil pressure light came on. I turned off the engine immediately, and coasted to a stop. Luckily I had a few litres of oil in the back. I refilled it which took over 3 litres. Oil has come out under pressure in a spray on the forward part of the engine on the left passenger side, just behind the pulleys. The spray of oil was under the bonnet in a small area, so I am hoping for just a burst pipe.
It was too dark to go digging, I will look at it tomorrow, but can anyone point me to any engine oil diagrams, or point me in the right direction.
59 plate defender 90 2.4.
Many thanks
Post #484671 22nd Dec 2015 11:22pm
ickle
Vacuum pump!
Post #484676 22nd Dec 2015 11:35pm
DAZ110
Yep...vacuum pump!
Post #484680 22nd Dec 2015 11:41pm
Rogeo1983
Ok guys,
Sounds like vacuum pump then!
Is it hard to replace? Is there any diagrams online to show what to look at?
Post #484681 22nd Dec 2015 11:46pm
Rogeo1983
I have just looked up the vacuum pump, and yes that looks like the source.
With the oil leak, where would the leak be from? Is it the gasket, or from the bearing.
Thanks guys, really appreciate the quick replies
Post #484684 22nd Dec 2015 11:50pm
Treebeard
United Kingdom 2005 Defender 110 Td5 CSW Chawton White
They cost about �100 and are simple to fit. latest pn was LR012183 when we did ours a couple of years back
Post #484692 23rd Dec 2015 12:26am
DAZ110
Post #484695 23rd Dec 2015 12:30am
Treebeard
Sorry pn was LR 014973
Post #484697 23rd Dec 2015 12:33am
Treebeard
Plus gasket LR 004381. All covered on page 191 of the defender tdci workshop manual which you can find as a pdf on www
Post #484699 23rd Dec 2015 12:43am
Rogeo1983
Thanks treebeard
I am guessing that your link www was reference to the lack of workshop manuals!!!
I will pick one up tm and I think I will do a full service while I am getting dirty anyway!
With the fact that this pump sprayed out oil under high pressure, is there anything else that I should be looking at while replacing the pump?
Does the vacuum pump have its own engine oil supply?
I don't quite understand how it works, or even why the engine oil is there under such high pressure.
Many thanks
Post #484701 23rd Dec 2015 1:12am
Quite the opposite - look at the link to the other thread:
Grockle wrote:
pm dgardel,he's the chap
but then it's even easier - this will get you there:
https://onedrive.live.com/?id=4BC2D89C85C7...9C85C7C171
Post #484761 23rd Dec 2015 11:12am
