![]() | Home > Puma (Tdci) > Spotlight high beam input |
| L90Andy Member Since: 29 May 2014 Location: Stratford-Upon-Avon Posts: 728
Factory kit takes feed from the main beam indicator light in the instrument panel. In the process of fitting the factory kit myself.
| Cetane Member Since: 27 Nov 2012 Location: Lancashire Posts: 171
Any ideas of location, colour etc?
Perhaps maybe a scan of the instructions? |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6733
Some docs here which may help: http://www.defender2.net/forum/topic41280.html
Andy's building up the courage 1988 90 Td5 NAS soft top
2015 D90 XS SW |
Blue with white is main beam
2015 D90 XS SW |
Well heres the manual for the Gen kit.
http://topix.landrover.jlrext.com/topix/service/document/70573 Seems TD5 spec. Looks like Im going to be digging behind my instrument binnacle for blue with a white stripe. |
Er I just posted a link to a thread with Puma docs
2015 D90 XS SW |
Sorry. Missed it. Was busy digging.
2015 D90 XS SW |
Unless I'm mistaken it says Blue/Orange in the instructions....
It does, sorry yes.
The Td5 wiring diagram I have shows blue/white at the instrument cluster, but Puma seems to be blue/orange. It's just taking a feed from the other side of the fuses. Blue/white is main beam switch supply to fuses. Blue/orange is main beam from fuse to right hand headlight. Blue/slate is main beam from fuse to left hand headlight. Basically it doesn't matter which of those you use. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
Tell me about it! Not looking forward to drilling the dash or cutting wires, but have all the bits now, apart from an econoseal connector. This will be my Christmas project! |
| Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123
As youre looking into the engine bay, the far right hand side. There is a connector in the corner which has all the wires for the lights, I took my relay feed from the blue with white/grey trace. Was much easier than pulling the dash apart.
| All times are GMT |
