![]() | Home > Puma (Tdci) > Spotlight high beam input |
L90Andy Member Since: 29 May 2014 Location: Stratford-Upon-Avon Posts: 728 ![]() ![]() ![]() |
Factory kit takes feed from the main beam indicator light in the instrument panel. In the process of fitting the factory kit myself.
Cetane Member Since: 27 Nov 2012 Location: Lancashire Posts: 171 ![]() ![]() ![]() |
Any ideas of location, colour etc?
Perhaps maybe a scan of the instructions? ![]() |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6684 ![]() ![]() ![]() |
Some docs here which may help: http://www.defender2.net/forum/topic41280.html
Andy's building up the courage ![]() ![]() ![]() |
Blue with white is main beam
Well heres the manual for the Gen kit.
http://topix.landrover.jlrext.com/topix/service/document/70573 Seems TD5 spec. Looks like Im going to be digging behind my instrument binnacle for blue with a white stripe. ![]() |
Er I just posted a link to a thread with Puma docs
Sorry. Missed it. Was busy digging.
Unless I'm mistaken it says Blue/Orange in the instructions....
It does, sorry yes.
The Td5 wiring diagram I have shows blue/white at the instrument cluster, but Puma seems to be blue/orange. It's just taking a feed from the other side of the fuses. Blue/white is main beam switch supply to fuses. Blue/orange is main beam from fuse to right hand headlight. Blue/slate is main beam from fuse to left hand headlight. Basically it doesn't matter which of those you use. ![]() ![]() |
Tell me about it! Not looking forward to drilling the dash or cutting wires, but have all the bits now, apart from an econoseal connector. This will be my Christmas project! |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
As youre looking into the engine bay, the far right hand side. There is a connector in the corner which has all the wires for the lights, I took my relay feed from the blue with white/grey trace. Was much easier than pulling the dash apart.
