Home > Puma (Tdci) > Dash fuse box cover fouling OBD adaptor
Dave Bellis
United Kingdom 2014 Defender 90 Puma 2.2 HT Keswick Green
I've fitted a blue tooth adaptor to the OBD port in the fuse box which now just about fouls the cover. Anyone any ideas of how to overcome this apart from dropping the OBD socket....
Dave
Post #470669 8th Nov 2015 1:57pm
K9F
OBD socket isn't obviously designed to have anything permanently fitted, 4 options I can think of,
Take the two mounting screws off of the OBD socket reroute it and it will fit.
Splice the 7 cables and relocate the OBD socket elsewhere. (Another security layer.)
Cut a hole in the front cover.
http://www.defender2.net/forum/topic24428....obd+socket
Fourth option is a bit more technical, involving an OBD connector a pcb and a bit of soldering....
fekete wrote:
Here you go...sorry for pinching your pic Thumbs Up
I'm interested
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  If you go through life with your head in the sand....all people will see is an ar5e!!
Post #470672 8th Nov 2015 2:02pm
X4SKP
Hello Dave Bellis
I went for the unsophisticated 'cut a hole in the front cover' route.
As K9F suggests relocating the OBDII Socket, has it's advantages... Thumbs Up
I have a replacement cover ready for this... just haven't worked out where to place the OBDII yet,
(and built up the courage to cut the Socket out... Shocked )
My need was in fitting a ScanGaugeII
 SKIP
Post #470678 8th Nov 2015 3:25pm
Dave Bellis
thanks for the replies, your hole cut looks pretty neat any tips....
I'm thinking of doing this as I need viewing access to the adaptor...
Dave
Post #470743 8th Nov 2015 6:19pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Re locate the OBD socket, then get an OBD splitter, this will enable you to keep the gauge plugged in, and still have a fully functional OBD socket under the dash panel.
 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #470756 8th Nov 2015 7:09pm
