![]() | Home > Puma (Tdci) > Dash fuse box cover fouling OBD adaptor |
Dave Bellis Member Since: 21 May 2014 Location: Shrewsbury Posts: 133 ![]() ![]() ![]() |
I've fitted a blue tooth adaptor to the OBD port in the fuse box which now just about fouls the cover. Anyone any ideas of how to overcome this apart from dropping the OBD socket....
Dave |
OBD socket isn't obviously designed to have anything permanently fitted, 4 options I can think of,
Take the two mounting screws off of the OBD socket reroute it and it will fit. Splice the 7 cables and relocate the OBD socket elsewhere. (Another security layer.) Cut a hole in the front cover. http://www.defender2.net/forum/topic24428....obd+socket Fourth option is a bit more technical, involving an OBD connector a pcb and a bit of soldering....
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Treat every day as if it is your last....one day you will be right!! |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2303 ![]() ![]() ![]() |
Hello Dave Bellis
I went for the unsophisticated 'cut a hole in the front cover' route. As K9F suggests relocating the OBDII Socket, has it's advantages... ![]() I have a replacement cover ready for this... just haven't worked out where to place the OBDII yet, (and built up the courage to cut the Socket out... ![]() My need was in fitting a ScanGaugeII ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge SKIP https://www.defender2.net/forum/topic83242.html |
thanks for the replies, your hole cut looks pretty neat any tips....
I'm thinking of doing this as I need viewing access to the adaptor... Dave |
