Home > Wheels & Tyres > From Sawtooth Alloys with 30mm Spacers to Wolf rims,
dave18
United Kingdom 1984 Defender 110 300 Tdi CSW Portofino Red
Hey peeps, Got a 1984 110, Currently run Gen Sawtooth alloys with 30mm spacers, Run summer and winter tyres and want a second set of wheels so I just change the wheels when needed. Im torn between either Boosts or WOLFs.
Now I know the Boosts I will need the spacers for but what about the Wolfs. Will it be ok to run the Wolfs with the spacers. Know I will need Steel nuts for them as well.
Post #469272 4th Nov 2015 10:15am
There's no reason why you shouldn't run the HD steel rims on spacers if you want to, but you will (as you comment) need the correct steel-wheel nuts for them.
The Wolf rims require a higher torque on the nuts than alloys but there will be no problem, provided that the spacers are of acceptable quality (and you wouldn't be using them if they weren't).
Post #469326 4th Nov 2015 1:02pm
Mike_B
United Kingdom 2006 Defender 110 Td5 USW Java Black
If it's easier for you, I'll collect the sawtooths and spacers to relieve you of this dilemma. You can be safe in the knowledge that your wolf rims are fitted directly to the hubs....!
Its for the best...!
Post #469331 4th Nov 2015 1:10pm
dave18
Blackwolf cheers thought so but wanted to double check,
Mike what about when spring comes round and I want to refit my sawtooths with Conti Crosstracs ?? There black BTW too and Gen LR 😉😂😂😂
Post #469412 4th Nov 2015 6:11pm
Stacey007
Hello
Have you a picture of the sawtooths and spacers on the 110?
what tyres do you use with them, as I'm thinking about spacers for mine
Thanks
Post #469486 4th Nov 2015 8:05pm
dave18
Stacey, I have pics of the Wheels which I will put up later. Got to take one of the wheels off so will get a pic of the spacers then, Mine are Terrafirma Spigoted alloys ones.
http://www.ebay.co.uk/itm/DEFENDER-90-110-...27f9d3e1ca
Post #469667 5th Nov 2015 10:36am
dave18
Hey peeps just a thought before I go and buy some would this not make my tyres stick out the arches ?? Running 235/85/16???
Post #472236 13th Nov 2015 2:52pm
fen
United Kingdom 2013 Defender 90 Puma 2.2 HT Havana
No they wouldn't , mine has 265 tyres and spacers
Post #474387 19th Nov 2015 10:24pm
MuddyChris300tdi
United Kingdom 1995 Defender 130 300 Tdi HCPU Alpine White
Here's my 265x75 on wolf's on 30mm spacers.
Post #474412 19th Nov 2015 11:20pm
