![]() | Home > Wheels & Tyres > From Sawtooth Alloys with 30mm Spacers to Wolf rims, |
There's no reason why you shouldn't run the HD steel rims on spacers if you want to, but you will (as you comment) need the correct steel-wheel nuts for them.
The Wolf rims require a higher torque on the nuts than alloys but there will be no problem, provided that the spacers are of acceptable quality (and you wouldn't be using them if they weren't). |
Mike_B Member Since: 23 Jan 2011 Location: Moray Posts: 550 ![]() ![]() ![]() |
If it's easier for you, I'll collect the sawtooths and spacers to relieve you of this dilemma. You can be safe in the knowledge that your wolf rims are fitted directly to the hubs....!
Its for the best...! |
dave18 Member Since: 11 Jul 2015 Location: Gorleston, Great Yarmouth Posts: 497 ![]() ![]() ![]() |
Blackwolf cheers thought so but wanted to double check,
Mike what about when spring comes round and I want to refit my sawtooths with Conti Crosstracs ?? There black BTW too and Gen LR 😉😂😂😂 |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3855 ![]() ![]() |
Hello
Have you a picture of the sawtooths and spacers on the 110? what tyres do you use with them, as I'm thinking about spacers for mine Thanks |
Stacey, I have pics of the Wheels which I will put up later. Got to take one of the wheels off so will get a pic of the spacers then, Mine are Terrafirma Spigoted alloys ones.
http://www.ebay.co.uk/itm/DEFENDER-90-110-...27f9d3e1ca |
Hey peeps just a thought before I go and buy some would this not make my tyres stick out the arches ?? Running 235/85/16???
fen Member Since: 18 May 2014 Location: Newcastle Posts: 4 ![]() ![]() ![]() |
No they wouldn't , mine has 265 tyres and spacers
MuddyChris300tdi Member Since: 02 Mar 2014 Location: Derby Posts: 225 ![]() ![]() ![]() |
Here's my 265x75 on wolf's on 30mm spacers.
