Home > Puma (Tdci) > VIN - Class W (extra heavy duty) Defender 90
thor44
2014 Defender 90 Puma 2.2 SW Indus Silver
Hi, after trying to decode my VIN (SALLDW....) with the workshop manual, I've found out that my MY14 Defender 90 seems to be a 90 inch Extra heavy duty one. Does anybody know what in this case "extra heavy duty" means or if there are even any standard ones (for the 90: SALLDV...) around?
Apart from the heavy duty rims, everything seems to be pretty standard to me....
Post #467244 28th Oct 2015 12:30pm
Browny90
United Kingdom 2004 Defender 90 200 Tdi SW Stornoway Grey
Is it Genuine Wolf spec? Wolf's have heavy duty chassis & drive train etc aswell.. did you buy it new? My 1986 90 is currently on a full rebuild, with new chassis, Paint etc.. Very much a hybrid, TD5 Chassis, tub & bulkhead with a 200TDI and LT77 GB Painted in Stornoway Grey Smile 2 years off the road, but getting close to completion now
Post #467249 28th Oct 2015 12:52pm
K9F
Early XS Pumas had HD suspension as standard that gave a 1" lift over standard. Have you spoke to your dealer? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #467257 28th Oct 2015 1:20pm
thor44
Jep, I've got it new from my dealer but it was already preconfigured and I highly doubt that they selected any HD specs as I would definitely have had to pay for that.
As for now I haven't contacted my dealer about it.... Wink
Post #467271 28th Oct 2015 2:08pm
shaggydog
Have a look at your chassis. If it has a continuous plate welded top and bottom along the entire length then it is probably a HD version.
Ether way its the better way round to be! Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #467272 28th Oct 2015 2:10pm
alby
United Kingdom 2015 Defender 90 Puma 2.2 SW Santorini Black
I have a 2014MY 90 SW. It was bought pre-registered from a dealer, built April 2014, but not registered till september, and then bought by me in feb of this year with a very hefty discount. I could never get a straight answer from the dealer about it, its an odd spec, being a base spec that has been specced up to almost county spec, minus a few bits and pieces.
My chassis number begins SALLDW..... noticed it a while back but never really thought about it, all previous have been SALLDV...
have just had a look underneath and it seems to look the same as other defender chassis I've owned, the main rails being formed from two C sections welded top and bottom.
I can though see the sticker from GKN Autostructures on the chassis, no mention of it being heavy duty.
Post #467282 28th Oct 2015 2:54pm
thor44
It should be pretty much the same for me...unfortunately I can't read the sticker anymore because of the heavy duty rust proofing Very Happy
Post #467286 28th Oct 2015 3:00pm
alby
I can't read mine either anymore, thanks to rustproofing, but I'm a nerd so I photographed all of the part number stickers on the defender when I first got it.
Post #467293 28th Oct 2015 3:26pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
I asked a similar question a while ago http://www.defender2.net/forum/topic39672.html
The owners manual refers to HD versions in various specification tables, but as of yet I haven't got a clue what the difference is. It seems "HD" is actually "standard" at least for XS`SW.
edited because link didn't seem to work, even though it looked correct?
Post #467375 28th Oct 2015 8:36pm
thor44
The topic about the vin of the 2,000,000 Defender was my reason to ask this question in the first place, too. Very Happy Quite strange that they even mention the extra heavy duty in the workshop manual then. Probably another Land Rover thing we are not supposed to understand. Anyhow thanks a lot for your responses. Thumbs Up
Post #467380 28th Oct 2015 8:42pm
Bionicmunky
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Santorini Black
my 63 plate 90 XSW is also a SALLDW......
Post #467402 28th Oct 2015 9:51pm
WhiskyJackR
My 63 plate is also DW
Post #467535 29th Oct 2015 2:06pm
X4SKP
Hello thor44
Interesting...and I don't know the answer, mine too is SALLDW------------
MY2011 2.4tdci Standard, as far as I know...at least when it left Land Rover... Exclamation
Someone will know on here... Thumbs Up
 SKIP
Post #467573 29th Oct 2015 4:53pm
NinetyTD4
Wales 2012 Defender 90 Other SW Keswick Green
Mine was ordered standard as well, but came HD. Checked it and found: chassis frame with some additional strengthening, HD springs, Wolf rims - mechanics suspected it was a frame originally aimed for some kind of military use. Never forget: cars have owner, Landrover have field service personnel.
Post #470282 7th Nov 2015 4:42am
thor44
@NinetyTD4: That sounds quite interesting. Could you possibly post some information about the reinforced chassis frame in this topic: http://www.defender2.net/forum/topic39672-15.html Thumbs Up
There we're currently collecting information about what the "extra heavy duty" actually means. As for now, we identified HD springs and vented front brakes as possible identification properties.
Post #470338 7th Nov 2015 11:17am
