![]() | Home > Maintenance & Modifications > A bar fitting kit |
TDCi Guy Member Since: 17 Aug 2014 Location: Yorkshire Posts: 286 ![]() ![]() ![]() |
I've managed to get hold of a non-winch soft a bar without the fitting kit.
After some googling I think the part number for the kit is VUB501800. It's the bar that needs the two plastic covers on the front This part doesn't seem to be available at the usual suppliers. Hss it be replaced by another or is it just no longer available? Tom @tditomprice 100” Defender Hybrid 2010 Alaska White 90 HT |
Thanks nitram. Will put a post up in the wanted section.
![]() @tditomprice 100” Defender Hybrid 2010 Alaska White 90 HT |
L90Andy Member Since: 29 May 2014 Location: Stratford-Upon-Avon Posts: 728 ![]() ![]() ![]() |
Is this what you're after ?
http://pages.ebay.com/link/?nav=item.view&...mp;alt=web |
Nope that's the kit for the newer type without the plastic front covers.
Thanks anyway Andy ![]() @tditomprice 100” Defender Hybrid 2010 Alaska White 90 HT |
glpinxit Member Since: 31 Jul 2010 Location: rural Somerset Posts: 159 ![]() ![]() |
Somewhere out there is a TD5 90 wearing a soft A-bar (with the pre-2007 front panels) mounted on brackets made by me. I was a bit grumpy to have to after it turned up with out them which wasn't made clear in the eBay advert. It took a bit of imagination as I had no photos or drawings but turned out well in the end. Sorry, I didn't keep drawings - messing about with cereal box card should get you the basics and I used 3mm steel left over from chassis repairs. Cheers, Guy.
