Home > Technical > Passenger side lights and dash lumination not working
TACK
connected a trailer to the electric socket on the tow bar and lost the function of the rear light, brake and front side light all on the passenger side. I have also lost the lumination of the dash too Shocked
Main beam works passenger side and I have checked the fuses and all seams ok, I am not too electrical minded, any suggestions on what to check or where to look for the fault Question Big Cry
TACK
Post #46573 28th Nov 2010 10:22pm
AndrewS
Have you checked the fuses under the drivers seat 130's have feeling's as well you know Smile
Post #46574 28th Nov 2010 10:26pm
TACK
Yes bud, went there first as I knew each light will have it own fuse and this must be a master fuse or something to knock the lot out Confused
Post #46576 28th Nov 2010 10:34pm
landy andy
Have you removed the trailer?
Any better/different?
Andy
Post #46578 28th Nov 2010 10:38pm
Peter Td4
Belgium 2008 Defender 110 Puma 2.4 HCPU Santorini Black
I've had this problem too on my Td5 Embarassed.
It was a fuse in the separate fusebox under the dashboard.
Unfortunately I don't remember which one. Peter,
Defender 110 StaWa - Td5
Defender 110 HCPU - Puma
Defender 90 Soft Top - Td5
Post #46579 28th Nov 2010 10:40pm
TACK
Andy, Disconnected the trailer electrics straight away and the lights stayed off. Turned the vehicle off, locked it, unlocked it and the lights remain dead, been like it for 24hrs now. Probably did not need to do that but things like that always worked in my d3 Laughing
Peter, mines a puma, so dont know if this would be different or where this suspect fuse could be located Question
Post #46582 28th Nov 2010 10:46pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Definitely sounds like a fuse to me.
I can't think which one off the top of my head. I'll have a look tomorrow. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #46587 28th Nov 2010 11:16pm
TACK
Cheers Alan Thumbs Up
Post #46605 29th Nov 2010 9:20am
Fuse F18 in the main fuse box (under the steering column) protects the NS side & tail lights
Fuse F13 in the main fuse box (under the steering column) protects the brake lights (both sides)
Instrument illumination is not specifically listed on the fuse spec but could well be off F18 too.
There is no single fuse the failure of which could cause all the symptoms you describe!
Post #46609 29th Nov 2010 10:35am
Lorryman100
I use one of these to check trailers electrics before connecting to landy, you can also check vehicles wiring as well Thumbs Up
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...616wt_1135
Post #46629 29th Nov 2010 1:50pm
alantd
Wot he said Thumbs Up One that started out as a 2.4 TDCi 110 XS
Post #46650 29th Nov 2010 6:34pm
Martin
Site Admin
Odd failure, as the brake lights are fused as a pair (Fuse 13 as above) Confused Maybe it's a coincidence and the LH brake light bulb has blown?
The LH side lights are fused separately from the RH, and are via Fuse 18 as above.
Have you lost the speedo illumination and the switch/control illumination - or just one?
Switch/control illumination is Fuse 20, speedo illumination is via LH side lights feed - so Fuse 18.
These are all in the steering column fuse box not under the seat.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #46655 29th Nov 2010 7:50pm
TACK
Cheers Martin.
Pulled all the fuses out last night, i mean every single one with very cold hands. none of them blown, gave up and surrendered to the comfy living room. Set off this morning, err dash lights are working Shocked got out, all lights working. Did not test the lights last night after I pulled them all out. Losse fuse Question not really as I had pulled the relevant fuses out (F18 and F13) the day before and did not work.
Will keep an eye on it but seams back to normal with no expanation Confused
Thanks for your help guys Thumbs Up
Post #46744 30th Nov 2010 2:13pm
X4SKP
Hello All
I had exactly this issue today...(checking the 90 as MOT tomorrow... Shocked )
Also Rear Number Plate Bulbs (X2 blown)... hopefully separate issue.
Searched on D2N, found a similar issue here...which made me worried initially... Exclamation
http://www.defender2.net/forum/topic28957....ts+working
as I have installed a OEM Land Rover 13Pin Towing Loom 3 months ago but to-date
without issue.
Arrived at this thread, and Fuse F18 is the culprit so a simple fix...
feeling like it can't be that easy can it... Question
Off to buy Number Plate Bulbs and a Spare Box of Fuse's.
Thanks D2N, it's like having your own mechanic... Thumbs Up SKIP
Post #461511 8th Oct 2015 10:11am
