![]() | Home > Puma (Tdci) > Electrickery |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
![]() Well short history. The fuse for the side ligths on the left side has burned 2 times and also the illumination and the side lights On Indicator of the instrument cluster are not working. Probably some shotcircuit somewhere. Any tought regarding were I must to start to look? Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Bit of a long shot but personally I'd start with the tow electrics, i.e. where you plug in the trailer socket and up to the loom plug behind the rear panel on the right hand side.
Problem found.
A cable in the rear part has been damage during a past accident and the joint done has not been quite good. By the time the cable was peel off and make contact with one of the side panel, so now all the system working 100% ![]() Cheers. Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
