Home > Maintenance & Modifications > How to remove sheared off rear tub bolt
RRUK
One of my rear tub to crossmember bolts has been sheared off by someone. I think it had a rear ladder and the removal of it was the cause.
The head has sheared off under the surface and the thread is held in the captive nut behind. (I presume it's a captive nut behind otherwise it would just pull out)
How on earth do I get that out? Shocked 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #449134 25th Aug 2015 5:02pm
Happyoldgit
Apply penetrating oil and leave for a while then centre punch the bolt, drill a pilot hole and enlarge to fit the bolt extractor [easy out] of your choice. The heat from drilling will occasonally be enough to free up a siezed bolt. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #449156 25th Aug 2015 5:46pm
RRUK
I guess I need a bolt extractor then... 2016 D4 HSE
Post #449158 25th Aug 2015 5:47pm
keith
Just yesterday I replaced all door and body bolts on a 2010 90 . 6 of the 10 rear tub bolts were corroded solid and heads sheared off .
As above , I bought new drill bit and drilled the bolts right through , replacing with stainless and rear nut.
A pain in the hass but welcome to landrovering.
Keith
Post #449162 25th Aug 2015 5:58pm
Dave Bellis
United Kingdom 2014 Defender 90 Puma 2.2 HT Keswick Green
Are the rear tub nuts captive, if not how easy are they to replace for ss.
Dave
Post #449188 25th Aug 2015 6:56pm
keith
No . Footery .
Post #449191 25th Aug 2015 7:00pm
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
Also - a left handed/ reverse drill bit is a usefull tool, the heat and vibtpration often loosens the bolt, and if that doesn't work at least you have a hole to use a easy out extractor
Post #449240 25th Aug 2015 9:46pm
