![]() | Home > Maintenance & Modifications > How to remove sheared off rear tub bolt |
Apply penetrating oil and leave for a while then centre punch the bolt, drill a pilot hole and enlarge to fit the bolt extractor [easy out] of your choice. The heat from drilling will occasonally be enough to free up a siezed bolt. Steve.
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2028 ![]() ![]() |
I guess I need a bolt extractor then... 2016 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2267 ![]() ![]() |
Just yesterday I replaced all door and body bolts on a 2010 90 . 6 of the 10 rear tub bolts were corroded solid and heads sheared off .
As above , I bought new drill bit and drilled the bolts right through , replacing with stainless and rear nut. A pain in the hass but welcome to landrovering. Keith |
Dave Bellis Member Since: 21 May 2014 Location: Shrewsbury Posts: 133 ![]() ![]() ![]() |
Are the rear tub nuts captive, if not how easy are they to replace for ss.
Dave |
No . Footery .
Daisy90 Member Since: 01 Feb 2015 Location: Hampshire Posts: 845 ![]() ![]() ![]() |
Also - a left handed/ reverse drill bit is a usefull tool, the heat and vibtpration often loosens the bolt, and if that doesn't work at least you have a hole to use a easy out extractor
