Home > Puma (Tdci) > HELP no headlights.
Page 2 of 5 <12345>
driver9
Post #300788 21st Jan 2014 8:49am
NoDo$h
Isn't that relay between the live feed and the switch, then on to Headlamps, with the switching source being the ignition? It still routes power through the switch.
Or have I got the diagram upside down? Confused
54 Freelander modded for mud
2008 D3 SE
2010 90 XS SW
1978 88 Series 3 undergoing surgery with a new owner
2007 90 County Truck Cab - gone
2006 D3 SE - gone
2004 Freelander Sport - gay
1999 Disco V8 ES rotted to bits
Post #300791 21st Jan 2014 9:07am
Yes, that's right. The relay does not protect the switch, hence all the threads about melting switches and replacement looms. Darren
Post #300793 21st Jan 2014 9:13am
Arsath
United Arab Emirates 2010 Defender 110 Puma 2.4 CSW Fuji White
Hi All,
Has anyone got a perfect solution for the headlight issue? Mine stopped working today.. As others have experienced here when flashing all lights are working.. only when it is dipped nothing is working.. is there a upgrade kit for the entire lighting system? I am total newbie to Defenders.. any advice is much appreciated..
Post #444051 7th Aug 2015 5:41pm
munch90
yes looms are available to protect the switch
search on forum "headlight upgrade loom "
Post #444056 7th Aug 2015 5:47pm
munch90
+ added advantage of brighter lights as the lights get full voltage as new loom is relayed
Post #444063 7th Aug 2015 6:11pm
Eduardo
Again changin the bloody dip switch. I have all the things to do the loom but the time is scarce Sad Eduardo
Post #444069 7th Aug 2015 6:52pm
Arsath
Thanks! But I am still confused.. should I change the switch or the entire loom?
Post #444179 7th Aug 2015 11:49pm
Eduardo
You can change the switch but soon or later (more soon than later) you will be again in the same situation Evil or Very Mad
Cheers Eduardo
Post #444189 8th Aug 2015 4:53am
ericvv
Arsath wrote:
Hi All,
As said, headlight upgrade loom. Very good quality fully prepared easy to install looms are available from www.landreiziger.nl
All very well detailed in this thread here.
http://www.defender2.net/forum/topic26097....ndreiziger
Here is the link directly to the loom plus a new light switch
https://shop.landreiziger.nl/modificatie/m...elaar.html
Here the link to the loom alone
https://shop.landreiziger.nl/modificatie/m...elais.html
And here the link to the loom with ceramic light connectors
https://shop.landreiziger.nl/modificatie/m...toren.html
Comes with English language instructions, just make sure when ordering that you need those though.
Good luck.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #444190 8th Aug 2015 5:38am
munch90
replace switch to fix headlights ( commom problem )
Then add the upgrade loom to protect the switch , the loom is added extra to standard wiring , no need to touch standard wiring , only thing might be if yours has dim dip you will need to disconnect that part
Post #444194 8th Aug 2015 6:24am
Arsath
Thanks everyone .. I knew buying a Defender is like getting married.. Laughing but did NOT expect issues in the relationship this early.. Shocked you guys are life savers... Thumbs Up
Post #444229 8th Aug 2015 9:11am
shaun.mobile wrote:
2. rusty headlamp rings (dealer pointed out that they are a no cost option).
Confused What's a no cost option?
Post #444260 8th Aug 2015 11:50am
dorsetsmith
they stay rusty Mr. Green
Post #444263 8th Aug 2015 12:04pm
Arsath
Hi All,
For anyone wondering why use a relayed system, you will find a good explanation at below link..
How Relays Work
and I found a 5.33 Pound alternative to the Dutch one..
H4-H4-Headlight-Headlamp-Black-Booster-Wire-Harness-Cable
Hope this will work.. Whistle
Post #444503 9th Aug 2015 2:33pm
Page 2 of 5 <12345>
