![]() | Home > Puma (Tdci) > HELP no headlights. |
driver9 Member Since: 15 Oct 2012 Location: Suffolk Posts: 111 ![]() ![]() ![]() |
Also shown on the wiring diagram
https://skydrive.live.com/view.aspx?cid=4B...&wdo=1 |
NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972 ![]() ![]() |
Isn't that relay between the live feed and the switch, then on to Headlamps, with the switching source being the ignition? It still routes power through the switch.
Or have I got the diagram upside down? ![]() ![]() 54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
Yes, that's right. The relay does not protect the switch, hence all the threads about melting switches and replacement looms. Darren
yes looms are available to protect the switch
search on forum "headlight upgrade loom " |
+ added advantage of brighter lights as the lights get full voltage as new loom is relayed
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2112 ![]() ![]() ![]() |
Again changin the bloody dip switch. I have all the things to do the loom but the time is scarce
![]() MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Arsath Member Since: 20 May 2015 Location: Sri Lanka Posts: 133 ![]() ![]() ![]() |
Thanks! But I am still confused.. should I change the switch or the entire loom?
You can change the switch but soon or later (more soon than later) you will be again in the same situation
![]() Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
As said, headlight upgrade loom. Very good quality fully prepared easy to install looms are available from www.landreiziger.nl All very well detailed in this thread here. http://www.defender2.net/forum/topic26097....ndreiziger Here is the link directly to the loom plus a new light switch https://shop.landreiziger.nl/modificatie/m...elaar.html Here the link to the loom alone https://shop.landreiziger.nl/modificatie/m...elais.html And here the link to the loom with ceramic light connectors https://shop.landreiziger.nl/modificatie/m...toren.html Comes with English language instructions, just make sure when ordering that you need those though. Good luck. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
replace switch to fix headlights ( commom problem ) Then add the upgrade loom to protect the switch , the loom is added extra to standard wiring , no need to touch standard wiring , only thing might be if yours has dim dip you will need to disconnect that part |
Thanks everyone .. I knew buying a Defender is like getting married..
What's a no cost option?
they stay rusty ![]() |
Hi All,
For anyone wondering why use a relayed system, you will find a good explanation at below link.. How Relays Work ![]() and I found a 5.33 Pound alternative to the Dutch one.. H4-H4-Headlight-Headlamp-Black-Booster-Wire-Harness-Cable Hope this will work.. ![]() |
