![]() | Home > Puma (Tdci) > tdci gear change issue |
pumaxs Member Since: 18 Jul 2012 Location: Bath Posts: 180 ![]() ![]() ![]() |
Hi Martin,
I have a 2.4tdci, so can't really help you. However, try typing "2.2 Rev Hang" into the search box (it will throw up quite a few threads) & see if any describe the problem that you're experiencing. If not, then I'm sure it won't be too long before one of the more knowledgeable members makes an appearance. All the best, Andy '57 Defender 110 XS Station Wagon 2.4tdci |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
not sure if you do this or not but try keeping your foot on the revs when depressing the clutch, might help keep the revs up while changing gear.
Martin M Member Since: 28 Jul 2015 Location: Leigh Posts: 17 ![]() ![]() ![]() |
Thanks everyone for the quick response will try the Rev hang thread to so if this is same problem
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8461 ![]() ![]() ![]() |
You are joking I take it Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
How does it compared to the other defenders you test drove? Cheers
TDCi Guy Member Since: 17 Aug 2014 Location: Yorkshire Posts: 286 ![]() ![]() ![]() |
Hi Martin, the gear change takes some getting used to if you aren't used to driving one. I was the same when I first got mine, now (the majority!) of my gear changes are silky smooth.
On a different note, are you from Leigh Lancs? If so I'll keep an eye out for you, it's not a big place. ![]() @tditomprice 100” Defender Hybrid 2010 Alaska White 90 HT |
![]() not exactly.....I've not driven the 2.2 but does the rev hang work if you take your foot off the throttle and then operate the clutch? if not that's because I was lead to believe the gear harmonisation should see some throttle for it to operate. My understanding is there to help get a smooth gear change ie its better to change gear onto a reving engine and not one that's ticking over (does that make sense?). |
Thanks James was joking no previous experience of driving the 2.2 I test drove a 2.4 that belongs to my friend
Also think that maybe driving it too gently as I am short shifting at just under 2000 rpm think it needs a bit more pedal going to try tonight but it feels like slack in the gear train so when I change up the van feels like it bouncing forward and backwards
Yes tom am from leigh promised myself a landy for a coupleading of years now but as they are being discontinued thought its now or never love the van only arrived on Saturday and been at work so no real chance to drive it yet |
Think am being too gentle with it and not review it enough been short shifting as the gearing seems so low never had a land rover before live it though just need some advice as to if mines faulty or I am not driving it correctly |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18003 ![]() ![]() ![]() |
Excessive slop and backlash in the driveline is another well-known Puma problem. There are many places in the driveline where slop can develop, but the halfshafts and drive flanges are notorious. If you park on a level hard surface and apply the handbrake, see how far you can push the vehicle back and forth, and listen for clunks and noises from the hubs and axles. The transfer box, the clutch, and to an extent the infamous output adaptor shaft can all also contribute to this, so after the first test, put the car in gear (with the engine stopped), release the handbrake, and then see how far you can pucj it back and forth. Some movement is to be expected, but it shouldn't be much. A vehicle as new as yours should be fine, but there have been some which are not well assembled, and there have been case of accelerated wear, so it is worth a check. You can be gentle with a Defender too - you don't have to drive it as though you're wearing wellies! |
Thanks blackwolf will try later but I think it maybe my driving as never owned a defender before and have only driven about 10 miles in mine as it was delivered from dealer in Suffolk
Hi Martin
The 2.4 and 2.2's are different in the gear changing area due to the rev hold on the 2.2 to harmonise the change. First thing, when changing gear do the normal thing of foot off the accelerator and depress the clutch, don't hold the throttle down ! Secondly try going to higher revs in each gear, 2500 is a good place to start. When you press the clutch down you will notice the revs hang despite removing your foot from the throttle. After a few seconds you will see them start to drop. On my vehicle I tend to push 2800 revs drop the clutch, put into the next gear and wait for the revs to reach about 2000 and then release the clutch. As all the vehicles are different you will have to try to find the correct revs with a bit of trial and error. It sounds complicated but once you have mastered the technique the changes become very smooth. After 40 years of driving manual vehicles it took me a few weeks to master the 2.2 gear change but well worth it in the end ![]() I should add that once you are confident with the rev hang you can actually change up through the gears without applying throttle when releasing the clutch and there is not jerkiness or kangarooing - well you can in mine ! Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
