Home > In Car Electronics > Kenwood Cubby Active Sub Install
Page 3 of 4 <1234>
It's worth bearing mind the plate below the cubby is pretty thin and the running gear is right below!
Dynamat under the rubber but on top of the plate really helps not just ordinary noise / vibrations but the sub too as less vibration is dissipated into the plate and away.
And more bass into the Landy's body which makes it sound better and you'll get more of a bass feel too!
Also if your cubby is mounted on wood make sure you've got 100% contact between the plate, the wood and the bottom of the cubby as if it isn't again you'll lose some of the sound quality as it won't be fixed down tightly.
Ideally if you wanted best quality although I've never bothered to go down that route you really want a replacement plate that is much much thicker and heavier for better effect but that is easier said than done as it's not just a case of drawing round it and cutting out as it has a locating piece in the underside.
With these subs it's not worth bothering with unless you've got a fairly high powered sub but Dynamatting the plate and making sure it's located and secured very less will all help.
Post #428349 3rd Jun 2015 3:12pm
CarlS
2016 Defender 110 Puma 2.2 XS CSW Aintree Green
Thanks for the advice Steve Thumbs Up , I've got Dynamat to go in the truck so while the box is removed I'll put some on the plate ect.
The truck will have Dynamat installed, when I get around to it........ The spawn of AndrewS
2016 Defender 110 XS Station Wagon (Built on the last day, 59 from the end) - Dead
2016 Mini Countryman Cooper S All 4
2019 BMW R1200 GSA Rallye Sport
Post #428357 3rd Jun 2015 3:38pm
Well, that'll save you a job then in advance as if your doing it all you'll need to do it anyway.
Just fit and forget. Thumbs Up
It will certainly help for sure.
Post #428358 3rd Jun 2015 3:44pm
Tiger
I didn't use the brackets or fixing kit just used longer bolts and went through the cubby
Post #428361 3rd Jun 2015 4:22pm
CarlS
Nice one, thanks Tiger Thumbs Up
Got mine in over the weekend, sounds & looks the part Very Happy
Used M4x25 bolts to mount it on the cubby box.
Post #428362 3rd Jun 2015 4:38pm
LR90XS2011
working towards fitting one to my 2011 model so far have used an ISO extension to allow a splice into the front speaker wires without altering the original LR wiring used male and female bullets that fit straight into Kenwoods loom. I am happy with all the other aspects but am interested in a couple of things
1/ where have people run the wires from the HU to the cubby
2/ where have people picked up a 10 amp ignition switched supply, on the scheme fuse 4 appear to be spare, I don't particularly want to fit an additional relay or separate switch
thanks in advance DEFENDER 90 TDCI XS,
Post #439989 23rd Jul 2015 9:20pm
I'll 'PM' you. Thumbs Up
Post #440011 23rd Jul 2015 10:17pm
LR90XS2011
comprehensive pm received thanks DEFENDER 90 TDCI XS,
Post #440027 24th Jul 2015 6:15am
SteveK
United Kingdom 2002 Defender 110 Td5 HT Rimini Red
Also if your cunny is mounted on wood make sure you've got 100% contact between the plate, the wood and the bottom of the cubby as if it isn't again you'll lose some of the sound quality as it won't be fixed down tightly.
I thought a cunny was a growler and not a woofer!!!
Post #440364 25th Jul 2015 9:47pm
Rolling with laughter
Typo, damned iPad auto spell thinks it knows best!
Post #440367 25th Jul 2015 9:58pm
LR90XS2011
completed mine and am happy with the results which are much more noticeable than the Kenwood speaker upgrade previously done adds good bass and more general volume DEFENDER 90 TDCI XS,
Post #446298 15th Aug 2015 2:20pm
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
I've just ordered one of these to install onto the back of an Mobile Storage Systems cubby, is it advisable to fit any form of sound deadening (e.g. Silent Coat) between the sub and cubby or inside the cubby? The seatbox already has Noisekiller applied so hopefully that should help reduce the tinny vibrations from the seatbox lids
If anyone could advise on cable runs and the ignition fed live point for a late TD5 110 that would also be much appreciated Very Happy
Thanks in advance,
Harry
Post #453945 10th Sep 2015 3:39pm
TDCi Guy
United Kingdom 1996 Defender 110 300 Tdi HCPU Auto Keswick Green
Can anyone comment on how the Kenwood compares to the Alpine SWE1200? They both list peak power being 150W with no RMS power listed on the company websites.
Anyone done a comparison/had both? Tom
@tditomprice
100” Defender Hybrid
2010 Alaska White 90 HT
Post #453955 10th Sep 2015 4:41pm
DAZ110
I fitted my Kenwood sub today:
It ready fills out the sound by adding the bass notes. Thumbs Up
Post #460691 5th Oct 2015 5:05pm
Nice cubby lid Rolling Eyes
Can you send me some pics please Darren Bow down
Post #460695 5th Oct 2015 5:13pm
Page 3 of 4 <1234>
