Home > Td5 > Misfire, running rough - SOLVED!!! |
taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663 |
I'd get that filter changed asap. Could be that simple. I change mine every time I put fresh oil in (5-6000 miles).
A TD5 misfire could be all sorts, especially with no fauly codes. Wiring issues could be crank position sensor. This is quite volnurable (sp?) and when breaking down and cause the engine to run very lumpy. Do you have Air Con? Have a look see around the compressor to as things tend to rub on the housing. Was reasonably common. I know you did the loom, but worth checking them and cleaning all the plugs again. How does it start? And what priming noises do you get? Any low fuel pressure faults logged? How's the FPR? Any signs of leakage out the back diaphragm? How the injector balance levels on idle? And just above idle? Are all the earths in good fettle? |
27th May 2015 9:15pm |
It could also just be fuel!
^^^^^ Been there
27th May 2015 9:39pm |
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 |
Did the filter, nothing...
Off with the rocker cover. Behold, broken injector spring and the top of the injector had snapped off. Found the broken pieces right there.... Just changed the oil last week, but it will be a new round of oil and filters just on the off chance there is something else floating around in there. Going over the entire top surface of the head with a magnet to recover anything else that may be laying around. Click image to enlarge Click image to enlarge Click image to enlarge |
28th May 2015 1:45am |
Wow! Never actually seen that!
Whenywas the last time the injectors were adjusted? |
28th May 2015 7:40am |
No idea. I just bought the truck in September. I don't think there is an adjustment for them..
28th May 2015 5:45pm |
