![]() | Home > Technical > ATB (torsen) front and rear install |
How about this stuff here? Seems built to much higher quality specs with tighter tolerances....
http://www.entreq.de/reinforcement-gear/an...achse.html http://www.entreq.de/reinforcement-gear/an...ehmer.html You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
^^ agreed Eric, but given LR tolerances, things will wear unless you go fully ashcroft / entreq
I actually mentioned to Olaf when I was at Entreq that I saw these two new items, but he did not seem to see an urgency for me to have this done any time quickly now after he heard that I had LR replacement half shafts already since about a year now. Will have another word about it with him later this week when I will pick up the SVX.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
I have Aschroft too in the rear axle and believe they are a lot cheaper. Looks like Entreq doesn't even touch the front axle while you can get Aschroft for the front too. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 ![]() ![]() ![]() |
+1 for ashcroft shafts cvs and flanges 2004 TD5 Defender 90 xs station wagon
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17911 ![]() ![]() ![]() |
+ another 1 for Ashcroft.
ATB diffs F&R, HD halfshafts and flanges F&R, HD CV joints. At last a decent driveline! ![]() Just the D44 DC front propshaft and Ashcroft TB centre diff left to fit! |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
I have just ordered two ATB LSD from Ashcrofts so was wondering of those who have fitted these LSD, did you use a LSD gear oil in the diffs?? I was thinking along the lines of Fuchs Titan Race Syn 5 75w-90:
http://www.opieoils.co.uk/p-850-silkolene-...5w-90.aspx Any thoughts folks?? |
Fuchs Titan Race Syn 5 75w-90 is exactly what I am running in the OEM and now the ATBs
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 ![]() ![]() |
Bog std stuff in my rear axle. I was under the impression the atb doesn't need any special oils.
Ashcroft Transmissions say use standard oils in the ATB, ie the same as you would in LR diffs.
Beery Member Since: 16 Nov 2014 Location: NSW Posts: 36 ![]() ![]() ![]() |
Do the ATB's have any effect on turning circle?
Shouldn't but I'll confirm later - my front lsd is going in today
None whatsoever. Why would they? |
Mine did
![]() Fitted a new fulcrum too Transmission transformed ![]() |
